Cleaned TB, now high idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by udy2554, Jan 11, 2011.
  1. Jan 11, 2011 at 4:28 AM
    udy2554
    udy2554 [OP] NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    So...I cleaned the TB yesterday. Sprayed out and brushed and rinsed. Did it a couple times till all ran clear. Now my idle stays in the upper 900-1100rpms, even after warming up. Before I did all this, after warming up it would drop to the lower 700rpms, sometimes even the upper 600rpms.
    Is this just the computer getting used to the clean TB? Will it eventually "learn" all the parameters again and go back to what I consider "normal"?
    Any ideas anyone?
    Thanks in advance for any help!!
  2. Jan 11, 2011 at 4:40 AM
    TRDsport2010
    TRDsport2010 Grease Monkey
    Corey
    Houston, Texas
    2010 Silver TRD Sport
    I have had this happen a few times in the past in my shop but I used my scanner to reset the parameters. You may try disconnecting the battery for about ten minutes. (negative side only). Then key on.(wait 30 sec). start it up and let it idle for about 30 sec. then drive it for at least 5 min to relearn idle. Hope this works for you. Never had this happen with a 4.0 but it may work for you.
  3. Jan 11, 2011 at 8:21 AM
    udy2554
    Naples, NY
    Thanks Corey! I will give it a try this afternoon!:bowdown:
  4. Jan 12, 2011 at 7:28 AM
    TRDsport2010
    Corey
    Houston, Texas
    Hope it works! If not I'll do some research on a few sites I pay for at work to see what I can find out.
  5. Jan 12, 2011 at 7:37 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    It will go away after a couple of days and run like a champ. Did mine this past Sat. I have done it before with the same results. It's ok...
  6. Jan 12, 2011 at 2:41 PM
    udy2554
    Naples, NY
    I forgot to repost here, oops.
    Yesterday, I recleaned the TB and actually removed it to be more thorough. Did what Corey said and the idle is now back to normal. Once it's warmed up, I'm back to 700-720rpms.
    All is well in my head now too!!
    Thanks again Corey:yay::bowdown:
