Cleaning and re-oiling K & N filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Das it mang, May 28, 2019.
  1. May 28, 2019 at 11:56 AM
    Das it mang
    Das it mang [OP] Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Hey all,
    May be a very silly question, but if I can avoid spending the extra money then it will help me out greatly. I have left over spectre performance air filter oil from when I had my 1997 ram (before it was stolen, used to run drugs for 3 weeks, and burned to the ground; yikes). I was wondering when I get around to cleaning my K & N drop-in filter, can I use the spectre oil to re-oil the filter? It is not brand specific, correct?
    Thanks!
  2. May 28, 2019 at 12:00 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A can of K&N oil is like $10.
    I mean, you're "probably" fine, but not knowing the difference in the porosity of the filter materials, and the viscosity and other factors of the oils, I'd just buy the K&N stuff...
  3. May 28, 2019 at 12:22 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    AH, okay. Hate to say it but I hadn't even checked the price of the oil yet; just assumed I could save some $$ if possible. At 10 bones it's definitely not worth the risk then, if like you stated the viscosity of the oil may be different. I still have a good amount to go until it needs a cleaning, I just noticed I still had the bottle leftover. Thanks for your help!
    FirstTimeFirstGen likes this.
  4. May 28, 2019 at 12:43 PM
    jbrandt
    Justin
    yep, pretty inexpensive.
    https://www.amazon.com/99-0516-Air-...&n+filter+oil&qid=1559072601&s=gateway&sr=8-3
  5. May 28, 2019 at 12:55 PM
    Glamisman
    Glamisman Well-Known Member
    careful when re-oiling... MAF's dont like air filter oil.
    Das it mang[OP] likes this.
  6. May 28, 2019 at 1:10 PM
    jbrandt
    Justin
    If you dunk it in oil, yeah probably.
    I've never had a problem with my MAF when following the directions.
    I've got ~120k miles on mine and have had to clean the MAF once, and it wasn't oily...
    Currygoat and Das it mang[OP] like this.
  7. May 28, 2019 at 5:47 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Was about to ask how light of a layer I should do if that's the case. I have seen many people on here complaining about it, but with my Ram it never had an issue with the oil. Although, doubt it had a MAF. I usually would do a thin layer on both sides with the other filter, would that be appropriate in this case as well, then?
  8. May 28, 2019 at 7:31 PM
    jbrandt
    Justin
    The instructions just say to apply a thin coat on each pleat (1 side) with the sprayer 3" away, let it dry for ~20 minutes, then re-spray any white spots. I'm sure K&N has posted a video of the proper technique.
    With my "cold air" intake, good luck getting a thin even coat on the inside of the cone filter...
    I have a K&N on my dirtbike too, and this is how I've done it. I've ridden that thing in some really damn dusty conditions, and the inside has always been perfectly clean.
  9. May 28, 2019 at 10:08 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Lightly oil it (one smooth solid pass) and get a paper towel to soak up the extra. I still use KN filter and haven’t had a problem yet.
    OEM filter are just fibers. KN has the fibers and oil so I would think even if you didn’t put enough oil on the KN you still would be fine. You also have the engine oil and filter to do the job.
  10. May 29, 2019 at 2:19 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Makes sense, thank you all! Super appreciative of the help on here!
  11. May 30, 2019 at 9:50 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    I bought the K&N cleaning kit for my filter. The spray degreaser runs out much quicker then the oil (you only need a very light spray so it should last a long time). I just use Simple Green to clean the filter now and it works fine. Never seen any oil on my MAF...
  12. May 31, 2019 at 9:47 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    simple green soak to clean it. Blow it dry. Soak in Marvel M. Let it drip off . Re install. Several times over the last 3 years. No issues
