Cleaning Bugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MedlinAround, Nov 22, 2010.
  1. Nov 22, 2010 at 9:44 PM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Got some bug guts on the front of my truck and can not get them off. I've used pressure washer and brush. Took some quick detailer and the clay bar and still couldn't get it to come off. Help please :mad:
  2. Nov 22, 2010 at 10:11 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    May need to wet sand.
    But it may be a slightly different shade of color afterwords vs. the other non-sanded area of color.
    But I would try all other alternatives before this.....
  3. Nov 22, 2010 at 10:55 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    The Magic Eraser has worked for me in the past.
  4. Nov 23, 2010 at 1:03 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Magic eraser.....works!
  5. Nov 23, 2010 at 6:26 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might also try Goo-gone and let it sink in a while.
  6. Nov 23, 2010 at 6:28 AM
    Deano
    Deano Member
    Dean
    Iowa
    Sport access cab 4x4
    I had that trouble also and just waxed the heck out of the front of the truck and mirror pods. Then i use a car wash aftermarket liquid and water and let it soften for a short time and then use a plastic wrapped sponge thing that is a bug remover and works fine on the windshield also. Mine is a white taco so bugs really show up.
  7. Nov 23, 2010 at 6:32 AM
    ledge76
    ledge76 Member
    Nashville
    2010 TRD Off Road
    I have the same problem, i've got the super white and the bug guts leave a stain. I'll have to try the magic eraser.
  8. Nov 23, 2010 at 6:34 AM
    southerntaco889
    southerntaco889 Well-Known Member
    Bartow, GA
    07 PreRunner DC TRD Sport
    5100's @ 2.5/285 BFG A/T's/blacked-red badges/strobes/siren/PA/roof rack soon to come/brush guard soon to come
    x2 Did this before and it works well on my BSM. Be careful with some bug and tar removers though. I don't remember what brand it was but I had a couple of friends that had used it before and they actually took the factory clear off the bumper.:eek: Course that was probably cuz it was a dang Chevy lol. But anyway just throwin that out there. Don't want ya messin up the front end.
  9. Nov 23, 2010 at 6:34 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    This is one of the main reason why I got a clear bra. They come right off like a non stick pan.
  10. Nov 23, 2010 at 6:42 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Also you can use WD-40. I have used that and it works. On tar too. Just spray some on a soft towel and rub with some pressure. Don't use paper towel, will scratch the shit out of the paint! But that and goo gone will take the wax off too, so be sure to wax it up after your done.
  11. Nov 23, 2010 at 6:43 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Have you tried a tar and bug remover? I have a spray on type (gel) that works like a charm. You have to let it soak in though (the brand name escapes me). I'd be leary of using the pressure washer, this cheap-ass Taco paint may wear thin...
  12. Nov 23, 2010 at 6:50 AM
    southerntaco889
    Bartow, GA
    That too, I got the 3M all over the front of my bumper, grill, hood, front of the fenders and the mirrors and it rocks. You can almost wash anything off with a good garden hose.
  13. Nov 23, 2010 at 6:53 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Spray em reall good and let them soak, give em another spray and then wipe firmly. Repeat until removed.
    Best thing is to clean often before they get caked in and become part of the paint!
  14. Nov 23, 2010 at 7:02 AM
    pauls2ndblessing
    pauls2ndblessing Well-Known Member
    Paul
    Alabama
    06 PreRunner SR5
    This may sound weird, but a dryer sheet will also take them off. I know it sounds crazy but a dryer sheet, a littler water, wipe down the bug guts, let it sit for about 30 seconds then lightly scrub. Works like a charm.
    Paul
  15. Nov 23, 2010 at 7:12 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    A trick for motorcycle windshields will probably work on the truck too. Take a big towel, get it good and soaked, drape it over the area to be cleaned, and leave it there for an hour. Make sure it stays wet the whole time.
    The water softens up the guts and makes removal a breeze.
  16. Nov 23, 2010 at 7:21 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I've heard about the dryer sheet before! Never tried it though. And the towel sounds like a good idea too. Do you use hot or warm water?
  17. Nov 23, 2010 at 7:27 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    ^ not my suggestion, but I would bet warm would be better. Heat will help break it down better.
  18. Nov 23, 2010 at 7:35 AM
    Smellfunny
    Smellfunny Member
    South Carolina
    08 PreRunner DC OR-Rugged Trail Edition
    I attached 10 frogs to the front of my truck to get them before they hit the front. : ) Just don't tie them to tight or they will croak.
  19. Nov 23, 2010 at 7:44 AM
    mjp2
    NJ
    *groans*
    :p
  20. Nov 23, 2010 at 12:21 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    ....mine were so bad, I had to paint my bumper.
