Cleaning engine
Discussion in 'Detailing' started by Skeetdad, Feb 12, 2014.
  1. Feb 12, 2014 at 6:24 PM
    Skeetdad
    Skeetdad [OP] Active Member
    SoCal
    Totally stock 2014
    I just read the "hot or cold" thread on cleaning engines. As a moderately inept mechanic, what pieces absolutely should get covered with plastic before washing? What should not be powerfully directed at?
  2. Mar 7, 2014 at 6:06 PM
    TacoFlavouredKiss
    TacoFlavouredKiss Well-Known Member
    Kevin
    O CANADA
    I think it'd be better to just use a rag or something. I've seen someone high pressure hose their bay, not too pretty
  3. Mar 21, 2014 at 3:20 PM
    Roll Tide
    Roll Tide COO COO KACHOO
    Quinton
    Indiana, you dont wanna come here.
    01 TRD xtracab, lifted, sitting on dem dirty turty trees, actually they are clean.
    Stuff. Things as well. I like putting these on instead of those. You know, for likes.
    I've pressure washed mine at a Blue Beacon for years. Just leave it running, and stay away from the air box and let the chemicals do most of the work.
  4. Mar 21, 2014 at 8:12 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    I do it all the time. Just use it to blow off the suds. Don't hold it close to anything to be safe.
  5. Mar 22, 2014 at 8:16 PM
    JeanClaude
    JeanClaude Well-Known Member
    East Atlanta
    2009 Tacoma Prerunner
    With a cool engine, as long as you don't soak components down you will be fine.
  6. Mar 24, 2014 at 1:17 PM
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Here's a good video that Adam's Polishes did a while ago. The engine bay they used for demonstration isn't *that* dirty ...but I'm in total agreement with most of the techniques they cover.
    http://www.youtube.com/watch?v=rZvEZrgyoX0
  7. Mar 24, 2014 at 4:22 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I think the key is .....engine COLD and not a lot of pressure.
    I've only done mine a couple times in 7 years. I used to use Simple Green.....but that stuff is kinda corrosive.
    The last time I washed mine, I used DAWN Power Dissolver. Spray it on....let it sit for a few minutes and hose it off with no pressure and no scrubbing.
    It's probably not a 'detailers' choice - but it cleaned it up enough for me!!
