Cleaning Headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by stucksucksnayota, Mar 28, 2008.
  1. Mar 28, 2008 at 11:49 PM
    stucksucksnayota
    stucksucksnayota [OP] Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Couldnt find a thread about this but my right side headlight is what I would call fogged up on the inside of the lens.
    How do I clean it out
    Is the headlight sealed or can you take the it apart and clean the lens?
  2. Mar 28, 2008 at 11:54 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    If it's on the inside then I would say you are SOL.
  3. Mar 29, 2008 at 4:10 AM
    glassdoc
    glassdoc Well-Known Member
    Spring City, PA 19475
    04 DubCab 260,000 miles
    Stubbs Sliders, 2.5" lift, Ken-Mtn Bumpers, Leather Seats, AM/FM/CD/DVD & CB, IP Trans-Upgrade, (2) Trans Coolers, Synthetics Thru-out
    You could possibly try the infamous "black headlight mod" option (where you bake the headlight for an exact amount of time at a certain temp). This will enable you to get the housing apart so you can clean it, and reseal it..
    http://www.customtacos.com/tech/index.php?article=222
  4. Mar 29, 2008 at 7:09 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i think that mod is for the 2nd gen trucks only
    it only on the inside is it cracked or did it get full of mud maybee take it out and spray some cleaner and water in where the bulb goes
  5. Mar 29, 2008 at 7:21 AM
    evolution6972
    evolution6972 Well-Known Member
    yea i agree with taking it out and washing it from the inside and letting it dry well or use something on a rod to wipe it out mine are starting that nice fogging on the outside i been puting rainx on it and it helps to make them look normal
  6. Mar 29, 2008 at 2:08 PM
    glassdoc
    If its fogging up, there is a leak some where. It needs to be resealed regardless. may as well try to get it apart so you can clean it before sealing it back up. Check the lense and see if maybe you got hit by a stone, could be a small crack..
  7. Mar 29, 2008 at 2:21 PM
    cleanTRDmachine
    cleanTRDmachine watch the meat
    Kyle
    Q-Town, PA
    06 DC TRD
    tint gray camo seat covers debadged color matched grille surround off of 06 TRD sport grillecraft black mesh grille Hella 500's demudflapped Toyota rear leaf TSB (first edition) 265/75/16 BFG AT TA KO's Flowmaster Super 40 #952445 Maglite Mod AntennaX 13in antenna Painted Lower Valance Vision X H4 Xenon headlights Halo Solaris H10 foglights Velocity Offroad 2.5 leveling kit (removed) Spidertrax 1.25" wheel spacers Rocky Mounts Clutch SD bike mount 4ft combo lock cable for bed extender Stage I interior LED's Toytec 1.5" AALs Extang Trifold Signature Series Bed Cover Reese front mounted tow hook Icon Stage 1 Suspension
    Rain-x is not for plastic...it's not good for your headlights
  8. Mar 29, 2008 at 2:28 PM
    glassdoc
    As printed on the Rain X bottle:
    Precautionary Statement
    "Rain-X should not be used on plastic windshields or Plexiglas windows. It can cause permanent clouding and damage. First and foremost use common sense when applying this product,"
    Most headlamp lens have a UV coating on them, once removed and or damaged the lens will turn yellow, hazy, and become very brittle.
  9. Mar 30, 2008 at 8:03 PM
    evolution6972
    i agree but then what do we use to keep them looking clear and in good condition before i put anything on mine i have a little haze on the top part of the lens on the outside and thats when i started experimenting if i dont use rainx i tried waxing them also i just want them to stay clear i always clean them with a microfiber sponge very soft and always get bugs off of car after road trips
  10. Mar 31, 2008 at 1:44 AM
    glassdoc
  11. Mar 31, 2008 at 5:20 AM
    evolution6972
    never heard of that i shall look into it though thank you
  12. Mar 31, 2008 at 7:58 AM
    06tacoma
    06tacoma Well-Known Member
    Tampa FL
    06 PreRunner SR5 XS-P Trd Longbed Double Cab
    20" enkei wheel,BFG G-Force tires, BHLM, Smoked tail lights, 2 RE Audio 10s, Quantom 900watt amp,10000K HIDs headlights and fog lamps,Borla exhaust, Borla drop in filter,Debadged tailgate,Painted black tacoma badges
    I agree with glassdoc that what i use on my head lights but if they are pretty bad i would wet sand them then apply the meguiar's
  13. Mar 31, 2008 at 10:10 AM
    evolution6972
    no mine arent that bad just starting to look bad on the top of the lense i juat want them to stay clear
  14. Mar 31, 2008 at 11:00 AM
    glassdoc
    Most of the plastic lenses today are coated with a UV inhibitor. If you wet sand (even lightly) you will remove the coating therefore allowing the sun to cook the lens and make it brittle and yellow.. There are professional kits out there on the market for lens refinishing, it includes everything you would need including the UV clear coat protectant.
  15. Mar 31, 2008 at 5:53 PM
    stucksucksnayota
    Barry
    I think im going to try one of those kits that glassdoc is talking about.
    My buddy did it to his dodge today and it look alot better
    Thanks for all the help
