Cleaning the MAF sensor, found oil in intake
Discussion in 'Technical Chat' started by TODEOTA, Jun 14, 2012.
  1. Jun 14, 2012 at 10:55 AM
    TODEOTA
    TODEOTA [OP] Well-Known Member
    Jake
    Lewiston, ME
    2000 SR5 4x4 extra cab
    Horn upgrade, 2.5" Rough Country lift going in soon
    I just recently got a scan done to see why I was getting the CEL. Code was 171 - Mass Airflow Sensor. I popped open the intake hose and found quite a bit of oil pooled up in the MAF housing. I cleaned all that up, but I believe that the oil is coming from the vent tube that connects to the intake just before the throttle body and the rear of the driver's side valve cover. I couldn't quite tell, but is there a PCV at the valve cover? This is the only culprit that I can see that would be spewing oil inside the intake. I have also thought about re-routing said vent line into the bottom of one of the intake resonators to help catch excess oil. Any thoughts?
  2. Jun 14, 2012 at 11:07 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Thats weird sub to see any solution to this
  3. Jun 14, 2012 at 11:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Oil from the PVC. Oil vapor is condensing in the intake. Excessive oil is a sign of worn rings.
    If you have a supercharger, you need a catch can on the PCV line.
  4. Jun 14, 2012 at 11:58 AM
    TODEOTA
    Jake
    Lewiston, ME
    So there IS a PCV connected to that line? I don have a SC, but it sounds like I may need to use that resonator as a catch can.
    Worn rings.... greeeeaaaaaat! :rolleyes:
  5. Jun 14, 2012 at 12:27 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Compression test or leakdown test will tell you if there is a problem. If you have the tools, a leakdown test is the better option.
  6. Jun 14, 2012 at 12:39 PM
    TODEOTA
    Jake
    Lewiston, ME
  7. Jun 14, 2012 at 6:13 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Hi Jake, I don't know how many miles you have on your Taco and how long it has been since the PCV valve has been changed, but you may want to change it out. You will want to buy the dealer PCV valve and get the Rubber grommet that the PCV sets in on the valve cover. You may be losing vacuum around the PCV and that along with it not working is dumping the oil in to your intake. I hope this helps, Good Luck.
  8. Jun 15, 2012 at 8:41 AM
    TODEOTA
    Jake
    Lewiston, ME
    It's got 166K. I just ordered a new PCV and grommet. Cleaning off the MAF Sensor really helped a lot with the performance of the engine. No more dead spots, hesitating and clatter from the engine now. Pulls nice and smooth!
