Cleaning the Rear Drum Brake Assembly...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NeverB4, Oct 29, 2019.
Have you replaced your rear brake shoes?
  1. Yes
    11.6%
  2. No
    72.1%
  3. I plan to
    16.3%
  1. Nov 2, 2019 at 5:21 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Too cold right now. Maybe next spring/summer.
  2. Nov 2, 2019 at 1:51 PM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    The bolt for taking off your rear drums is an M8 x1.25 (metric obviously). Last month when I checked my rear drums @ 90,000 servicing they were frozen on. After beating on and bending two M8x1.25 bolts I finally squirted a tad of Locktite Penetrating oil in the holes and tried again an hour later. Drum broke loose with a loud CRACK! Both drums for that matter. Then of course sprayed complete drum with brake cleaner and scrubbed all the rust off with a wire brush. To my amazement the shoes and drums looked great and were within tolerance. The dealer did all my servicing since new until @ 80,000mi I started myself. Guessing they never pulled drums but always told me "they're real close of needing changed". Right.......
  3. Nov 4, 2019 at 10:27 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Of course not. But you left out the 5K recommended interval of rear brake service I mentioned. A lot can happen between 5 and 20K miles.
    You got it figured out and I can't expand on that great info you provided.
