Cleaning Wheels Help!!!
Discussion in 'Detailing' started by Max-4_Yota, Feb 15, 2010.
  1. Feb 15, 2010 at 1:43 PM
    Max-4_Yota
    Max-4_Yota [OP] The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I washed my truck yesterday and i cleaned my wheels (there aluminum bullet holes) but i couldn't get all the spots from the brake dust off. I scrubbed and scrubbed but still couldnt get it off, does anyone know the best way to get this off??
  2. Feb 15, 2010 at 1:45 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    if you leave brake dust on your rims too long it will actually etch into the rims and you'll never get it all off. A good non acid wheel cleaner may help.
  3. Feb 15, 2010 at 1:47 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  4. Feb 15, 2010 at 4:31 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'd suggest trying a clay bar or even a mild polish.
  5. Feb 15, 2010 at 6:39 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    thanks i have the mothers power ball but im not sure what wax to use.
  6. Feb 15, 2010 at 8:56 PM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    I have Mickey Thompson Classics and I have the same problem. I just cleaned mine today using the power ball and they look a lot better. You can only tell when you look at the rim up close but from far away you cant even tell. I'd still like to know how to get the small black dots off and Michael mothers has a specific wax/polish for use with the powerball.
  7. Feb 15, 2010 at 9:00 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Try brake cleaner.
  8. Feb 15, 2010 at 9:02 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    That could work, but it might take of the top coat of the wheels.;)
  9. Feb 15, 2010 at 9:02 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +1. Clay bar will work wonders. Give it a shot. Use some quick detailer or similar as a lubricant.
  10. Feb 15, 2010 at 9:05 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    I'd try a polish, not a wax first. Polish, meaning some type of light abrasive or chemical cleaner. You can always put some wax on later to help keep them clean. To protect, I like to use either collinite 845, optimum opti-seal, or poorboys wheel sealant.
    I wouldnt.
  11. Feb 16, 2010 at 10:27 AM
    topgun155
    Zack
    Richmond, TX
    2018 F-150 5.0
    The reason I suggest brake cleaner is because it took sharpie marker off my light color lazy boy chair. If it is gentle enough for that I think the rim can stand it. I just wouldn't recomend letting it sit.
  12. Feb 20, 2010 at 4:06 PM
    Prerunner Paul
    Prerunner Paul Member
    San Clemente, California
    02' PreRunner
    The best thing I do is, I use a little Acetone on a rag and wipe the bad areas, that will get the get it off for sure, without hurting the finish on the rim. Then I use a Brillo Pad, or S.O.S. Pads work good too, and scrub the whole rim. The pads are fine enough not to hurt the rim either. My truck is a 2002, and I've been cleaning the rims that way for 8 years now, and the rims look brand new. I think you'll be happy if you try this.
