clear coat recommendations
Discussion in '4 Cylinder' started by SurfInferno, Mar 1, 2010.
  1. Mar 1, 2010 at 12:49 PM
    SurfInferno
    SurfInferno [OP] Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
    I painted my grill (over the chrome) with krylon fusion, it doesnt but me that its matte but it does bug me that it chips really easy. is there a good clear coat i could use to help it from chipping?
    When i first did it it looked like crap (didnt sand the stubs all the way down to stotashi(sp?) it) so i had to respray it and when i did there were big areas bubbling up from the previous time. how can i avoid this?
  2. Mar 13, 2010 at 5:12 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    Did you respray with the same paint? If not, different brands of paint can react with each other, with the new one dissolving and lifting the old layer, that's what your "bubbles" sound like. I don't know how much you're looking to spend, but the toughest clear coat I know is something called Spraymax 2K. It's about $20 for a can though, and you need a good respirator (not one of those cheap paper filter types) to use it as it's a ureathane-type. If you lifted the paint, it sounds to me like you should probably start from scratch, sand off the paint and then buy all the same brand color and clear. Spray the whole thing in a day, with lots of light coats a few minutes apart. After you've got the color coat on, and put a few layers of clear on it, spray one or 2 more medium coats of clear and let it cure for a week before putting it back on.
