Clear Fluid Drip.
Discussion in '1st Gen. Tacomas (1995-2004)' started by dirtytaco, Oct 26, 2009.
  1. Oct 26, 2009 at 6:48 PM
    dirtytaco
    dirtytaco [OP] New Member
    baton rouge
    I bought a 2003 Taco from a local dealer. I noticed a few fluid spots on the driveway. I took a look under the truck and there is a clear drip on the passenger side. It comes from a aluminum tube sticking out of the firewall. I thought it had to do with the ac but it keeps leaking. Any suggestions whould be greatly helpful. I can post pics if needed.
  2. Oct 26, 2009 at 6:51 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Probably condensation from the A/C.
  3. Oct 26, 2009 at 6:53 PM
    dirtytaco
    baton rouge
    thats what i thought too but it drips for a long time and it there is a stain on the driveway from yesterday.
  4. Oct 26, 2009 at 6:55 PM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    I know during the summer I would park and come back out and it would be a lot of water running from the truck. But its nothing to worry about. Well that is if it is the AC.
  5. Oct 26, 2009 at 7:09 PM
    carmellocafe
    KEVIN
    N. California
    If it's "clear" I really doubt it's anything to be too alarmed about. Gotta be water--I can't think of anything else it would be coming from that area. I do know that the A/C does have a drain tube in that location though. And, if your in cool weather and running the defrost, it'll run the A/C to dry the air in the cab. :)
  6. Oct 27, 2009 at 10:29 AM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    +1
  7. Oct 27, 2009 at 12:07 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you put your finger in it? Smell it??
    Does it feel like water or oil?
    Does it smell like nothing or smell like oil?
  8. Oct 27, 2009 at 1:58 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    next to water the only clear liquid that could leak would be gas, and you would know if you were leaking gas if you stuck ya finger in it.
  9. Oct 27, 2009 at 3:27 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    it is water, mixxed with your Funk and the truncks funk...
    That water is mixed with the air in the truck.
    If you use allot of Product, or air freshners and junk, it might stain your drive way.
    This is normal..
  10. Oct 28, 2009 at 5:58 PM
    dirtytaco
    baton rouge
    I guess my only concern is how long the drip continues. I have been home for about an hour and I just checked it out...stil a little drip. How long does AC condensation drip last?
  11. Oct 28, 2009 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Depending on the humidity in your area, it can drip for a while.
  12. Oct 28, 2009 at 6:07 PM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Do you have the recirculate button off? That should help with the condensation.
