Clear Protectant (3M or?) replace Mudflap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Relik, Jun 23, 2011.
  1. Jun 23, 2011 at 2:48 PM
    Relik
    Relik [OP] Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys,
    I like most of you removed all my mudflaps on my 2011. Problem is I noticed on the bottom of the rear fender/bedside behind the tires there are quite a few scratches+chips already accumulated.
    Since im a Prerunner with shitty stock tires some offroad runs in the sand caused me to floor it a lot to get out of situations, so I can easily see this getting worse even will all around driving.
    Has anyone tried putting protectant film over this area instead of putting their mudflaps back on? This stuff is more known for front(hood+bumper) rocks/chips/bugs but I dont know of accelerated debris from tires.
    Thanks
  2. Jun 23, 2011 at 2:49 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subd...good idea? waitin to see what others say
  3. Jun 23, 2011 at 3:03 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    +1
  4. Jun 25, 2011 at 11:52 AM
    Relik
    Eddy
    Thousand Oaks, CA
    Bump
  5. Jun 25, 2011 at 11:56 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I think you have a good idea:). Post up pics if you do it. But IMO I think that it's a truck. If you want it to stay pretty don't take it off road. I look at all the chips/scratches as character and proof that I use my truck the way that I think trucks were intended. Just my .02
  6. Jun 25, 2011 at 11:59 AM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    you could try the film, and if that doesnt work then i would prolly put the mud flaps back on. i havent taken my mud flaps off for that rreason.
  7. Jun 25, 2011 at 2:27 PM
    TheGreekIndian
    TheGreekIndian Well-Known Member
    Doing this is about a week. I'll keep this thread updated.
  8. Jun 25, 2011 at 8:02 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    :spy:Watch out, the mud flap guys will be here shortly...
    Toyota does apply a "film patch" to protect the front area of the rear wheel fender flares already. You could apply a film to protect the other areas below, but from my experience, with the flaps removed on all the trucks from my past I have had no issues in the areas where the mud flaps protect. Sure, there were nicks in the paint from rocks and so forth along the bottom of every truck I have owned, but rust or paint issues were never a problem for me. At some point I would just cover the nicks or lower areas with a liner material of some sort if the nicks in the paint bother you...
  9. May 30, 2015 at 2:32 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Anyone in this thread end up actually doing the 3m clear bra?
  10. Jun 1, 2015 at 1:48 AM
    ODNAREM
    ODNAREM Well-Known Member
    Ron
    Huntington Beach,CA.
    2012 TRD sport PreRunner
    TRD catback exhaust,FJ Cruiser trail team wheels,BFG Rugged Terrain tires,Grillcraft front grill.
    Chips and scratches are going to happen and i look at it as its a truck being used the way it should be and adds some more character to it!Those general areas have factory clear protectant but it wouldn't hurt to do what you've thought of in the other areas.A friend of mine who has a Tundra actually plastidiped those areas with several coats.It has worked as a good shield for those areas of his truck and he has the option to remove it easily.
