Clear White Head Lighting!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08Tacoma, Jan 2, 2008.
  1. Jan 2, 2008 at 10:10 AM
    08Tacoma
    08Tacoma [OP] Well-Known Member
    Arizona
    2008 Tacoma, DblCab, 4x4, TrdSport, BlackSandPearl, 2.5" Toytec, TubeSteps, WindowTinting
    Can someone help me out with these!!
    I want to get that clear white lights for my 08 Tacoma, for the headlights and fog lights also, but I don't know wish are the bulbs that I need, can someone help me out please??
    Thanks.
  2. Jan 2, 2008 at 10:30 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I think people have been taking apart the headlamps and pulling the amber lens out.
  3. Jan 2, 2008 at 10:34 AM
    08Tacoma
    Arizona
    I am talking about the light bulbs, I want the light to be clear!!!
    Thanks for your help.
  4. Jan 2, 2008 at 10:43 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Try Sylvania Silver Stars. I think those are more of a white. I have them in my car, but the lenses are kinda yellowed so it's hard to tell. They did make the headlights brighter and less yellow-ish though!
  5. Jan 2, 2008 at 1:44 PM
    08Tacoma
    Arizona
    Does someone know a site where I can get them online!!
    Thanks.
  6. Jan 2, 2008 at 1:51 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Bought mine (for the car) at Wal-Mart. Now sure if they have the size used by the truck. I know I had to get the fog's at Auto-zone.
    Try autozone.com, checkers, parts america, maybe summittracing or JCwhitney.
  7. Jan 2, 2008 at 2:29 PM
    08Tacoma
    Arizona
    Ok Thanks..
    I have another question I hope someone knows about it. When I am driving at night with lights on, all the people think that I have my High Lights on, and they always switch lights at me, I am thinking that this might be because of the 2.5" front coil spacers that I installed in my truck.
    Does someone knows how can I get my lights as they were before the lift???
  8. Jan 2, 2008 at 2:36 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Did you put anything in the back for lift? Maybe the front is higher than the rear directing the beam upwards. I have a 3" lift, and 2" larger tires. Being 4" taller than stock I still do not get flashed. I would see if your truck sits level before messing with the lights. Other wise I believe you can aim them down. The dealer or another shop can do it, or you can do it. There's a wheel to turn, but I've never messed with it myself.
  9. Jan 2, 2008 at 4:07 PM
    08Tacoma
    Arizona
    Yeah, the front is a litle bit higer, I think I better take it to the dealer, so I wont messed up!!
    I did't get it phantom, thanks for your input anyway!!!
    Thanks.
  10. Jan 2, 2008 at 4:17 PM
    piercedtiger
    Jon
    Southern Tier, NY
    What parts of the toytec 2.5" lift did you install? If you have a .5" top spacer you might be able to remove that to level the truck.
  11. Jan 3, 2008 at 6:36 AM
    08Tacoma
    Arizona
    Ok phantom, I got it know bud, I'll do it tonight. Thanks bud'
    And piercedtiger, what I got is just the front coil spacers, thats all!!
  12. Jan 3, 2008 at 8:32 AM
    piercedtiger
    Jon
    Southern Tier, NY
    That's probably the problem. You didn't get the AAL or block for the rear. Do you have the rear leaf TSB done? If so, you still need a 1" block I believe to level it with the 3" front spacers.
  13. Jan 3, 2008 at 8:38 AM
    08Tacoma
    Arizona
    Actually is just a litle bit higher in the front, because when you get it stock, the rear is always higher than the front, that is why I got the spacers and I like it how it looks like that is not a lot the difference between the front and the back.
  14. Jan 3, 2008 at 8:43 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Then you could probably take out the .5" spacer from the front. You can adjust your headlights, but do you have fog lights? Because you can't adjust those and they will be angled slightly upwards towards peoples' faces too. It's better to level the truck, IMO.
  15. Jan 3, 2008 at 10:04 AM
    dbbd1
    dbbd1 Well-Known Member
    You can adjust the fogs, done it. I believe a 10mm socket (maybe 8mm) on the end of the gear-looking thingey. The gear-looking thingey looks just like the headlight adjustment thingey but the dished-out area is bigger, so you cannot just use a philips screwdriver, I even tried a #3 philips but the socket on the end of it worked.
  16. Jan 3, 2008 at 10:07 AM
    dbbd1
    FYI, though, the fogs are H10 size and the heads are H4
    (I am pretty sure about that, anyone vouch for this? doing it from memory)
  17. Jan 3, 2008 at 10:11 AM
    08Tacoma
    Arizona
    Ok I am going to try to adjust fog lights and headlights and see whats up..
    Thanks guys..you guys r awesome!!
  18. Jan 3, 2008 at 10:19 AM
    piercedtiger
    Jon
    Southern Tier, NY
    hmmmm.... My fogs are just snapped in with plastic tabs... No adjusting that I could see.
  19. Jan 3, 2008 at 12:47 PM
    08Tacoma
    Arizona
    That's awesome sir, I appreciate it!!!
    Great document!!!
  20. Jan 3, 2008 at 3:39 PM
    beondwacko
    beondwacko Well-Known Member
    West Palm Beach, Florida
    08' X-Runner , Sirius radio, fog light mod. Much more to go.
    Yep..............Those are correct.
    Not that I'm a grammer instructor or anything but what I think this dim bulb is asking for would be an HID set up. Could you just imagine how the people would be flashing him if he had 6K or 8K HID lamps in that truck?
