click/clunk after 5100
Discussion in 'Suspension' started by rab89, Nov 20, 2009.
  1. Nov 25, 2009 at 2:05 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Is the bolt torqued to spec?
  2. Nov 25, 2009 at 2:44 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    the top center bolt?
    I dunno, I had the mechanic swap it over for me, i'll check that tonight though.
  3. Nov 25, 2009 at 2:54 PM
    Dashe
    Dashe Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    check to see if they put the bushing on underneath the washer and nut on the top of the strut assembly. the shop forgot to put one of these on when they installed mine, and thank god i caught it before it caused any damage.
  4. Nov 25, 2009 at 3:50 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yep, bushing and washer are there.
  5. Nov 26, 2009 at 9:36 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    so, anyone know? is it normal for me to be able to twist my tie rod with my hand?
  6. Nov 26, 2009 at 10:12 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    dont have a answer for ya, but I know that I have a similar clunk,clank sound when going over bumps in the road at about 15-30mph.
    2 shops have checked it out and everything seemed fine and tight. So now I just ignore it. Oh and it started after installing my 3" lift.
  7. Nov 26, 2009 at 3:33 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    make sure the bottom shock bolt is tight, check sway bar bushings/endlinks and inspect the lower control arm bushings too
  8. Dec 16, 2009 at 7:27 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I'm working on it in the garage right now, with a cold canadian! here's to finding my clunk! (and a less boring bump than normal!)
  9. Dec 16, 2009 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man....how often does it make the click type sound?? does it do it while turning?
  10. Dec 16, 2009 at 7:44 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    It's only over a bump and only while turnong, I removed the boot on the steering rack, and there is a ball joint in there correct? it has play, I can see it and it's making an airy sort of noise, hard to explain that one, I'll get a pic... 1 sec
  11. Dec 16, 2009 at 7:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.......while its only while turning, and going over a bump.....im gonna say you are good to go. mine does the same thing....and its the "steering stop".......close to the bottom inside near the rotor.......mine does it on the driver side. pretty normal the older the truck gets.
  12. Dec 16, 2009 at 7:53 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    im having a simular clunk/squeek sound with mine also, over speed bumps too. i hear it more or maybe its just louder when its a bit colder out.
  13. Dec 16, 2009 at 7:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ball joint? it has play, I'm gona check the other side too, cause both are making the noise? if so, what would cause this to happen? I had my steering rack loosened to replace the rack bushings.. any relation?
  14. Dec 16, 2009 at 7:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    looks like normal wear to me....nothing bad that i see........clean it out a bit and put some grease back in.
  15. Dec 16, 2009 at 8:01 PM
    #35
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    i would like to replace it, what's that part called?
  16. Dec 16, 2009 at 8:04 PM
    #36
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    steering rack universal joint............its what i have always refereed to them as anyway.
  17. Dec 16, 2009 at 8:06 PM
    #37
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    alright, well thanks, I'm gona look around and see if there is any other possible noises.
  18. Dec 16, 2009 at 10:04 PM
    #38
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I have similar noise when going over bumps, when slowly moving and when jacking it. I notice it in the driver side only. I once cured it by spraying grease over the shocks, UCA , sway bay bushings. Now, it came back but won't disappear with re-spraying.
    Please update us of the findings.
  19. Dec 16, 2009 at 11:16 PM
    #39
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well, findings, seems to be both balljoints on the end of the steering rack, you can pull the rack boot off and see/feel the baljoint. check it out
  20. Dec 17, 2009 at 2:57 PM
    #40
    EmoSlayer
    EmoSlayer METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    I just had same snap/pop when beginning to drive from braking or going in reverse from stop. The long ass bolt going through the uca was loose and it was sliding back and forth as i accelerated or went in reverse, check that out it was my problem.
