Click/clunk/knock when brakes applied
Discussion in 'Suspension' started by Zac808, Dec 5, 2012.
  1. Dec 5, 2012 at 4:20 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I have a click/clunk/knock whenever my brakes are lightly applied. Seems like if the the truck is pushed back due to acceleration and then rocked forward by tapping the brakes there is a clunk coming from my front suspension somewhere. I checked lugs, tie rods, and general suspension components and for the life of me can't figure out where it's coming from. Any thoughts?
  2. Dec 5, 2012 at 4:31 PM
    ekapec
    ekapec Well-Known Member
    Erik
    AZ
    08 sr5 prerunner
    ultragauge, Cupholders painted black, Pop & Lock, N-Fab Light bar, Aux backup lights, kc daylighters, hella 500ff driving lights, fog lights. Leer cap w/roof rack and rocket box. Pioneer avh1400 dvd. Backup camera.
    I have the same thing, had it since I bought it and I believe I read somewhere else on here that its just something that happens. Iv put 20k on my baby and it hasn't gotten worse. Hope im not wrong in that its no big deal!
  3. Dec 6, 2012 at 12:49 PM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    take a look at your swaybar, how close is it to your coilover coil seat on both the drivers side and passenger side?
  4. Dec 6, 2012 at 1:02 PM
    BAMFTACO
    BAMFTACO CASH ME OFFROAD HOW BOUT DAT
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Could be the sway bar if the op didn't buy the sway bar relocation mount and could be the upper control arms. Or maybe the leaf springs are are loose in the rear
  5. Dec 6, 2012 at 1:05 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Sway bar is removed. I will ck leafs.
  6. Dec 6, 2012 at 1:07 PM
    BAMFTACO
    Jośe
    Taco
    How much did you torque your ubolts
  7. Dec 6, 2012 at 1:15 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    75 ft lbs, I think. Whatever spec is. I was a while ago. Bit seems like it's come from the front. When I hit speed bumps in the front I get the same click.
  8. Dec 6, 2012 at 1:20 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Front brakes are a floating type so they will click/clunk/knock when they seat themselves.
    Could also be:
    entire front end
    :D
    Bushings upper/lower
    Ball joints upper/lower
    Wheel bearings
    Dust shields
  9. Dec 6, 2012 at 7:57 PM
    BWro
    BWro Well-Known Member
    I had the same issue. The cause...the pins were corroded/bent. So the pads weren't "floating"
