Click sound, won't start
Discussion in 'Technical Chat' started by coltonwynn, Oct 29, 2009.
  1. Oct 29, 2009 at 9:57 AM
    coltonwynn
    coltonwynn [OP] New Member
    First off new to this forum but have been lurking in the shaddows for a while!
    I have a 1996 toyota tacoma V6 manual It has had this problem for about 5 or so months now when I go to start it it will just make a click sound some times it takes two or three tries for her to start up other times it takes for ever to get it started.... Every once in a while it will be in a good mood and start first try and keep doing that for a few days then go back to taking 15 min to get it started...
    Also some times my stero will all be set back to normal like when I first put it in and have to reset all stations and bass... The clock has never been reset though but does go dim when it clicks I have replaced my battery checked my fuses and cleaned my terminals and tightend all screws from my positive wire all the way down...
    Any help would be great
    thank you
    colton
  2. Oct 29, 2009 at 9:59 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Sounds like your starter is failing, mine did the click thing when it died, or the electrical connection to your starter is loose.
    robssol likes this.
  3. Oct 29, 2009 at 9:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    The contacts in the starte are shot. You have two options, replace the contacts or the starter. The contacts are cheaper then replacing the starter
    robssol likes this.
  4. Oct 29, 2009 at 10:01 AM
    coltonwynn
    How do i replace the contacts?
  5. Oct 29, 2009 at 10:03 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Oct 29, 2009 at 10:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'd start with the battery..... check & clean the connections on the battery first & foremost. Clean and make sure the connections are tight.
    How old is the battery?
    From there - check the electrical connections at the starter.
    Markcal likes this.
  7. Oct 29, 2009 at 10:08 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    X2
    Markcal likes this.
  8. Oct 29, 2009 at 10:10 AM
    coltonwynn
    brandnew
  9. Jul 15, 2016 at 11:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob starter is almost worn out.
  10. Jul 15, 2016 at 11:57 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How is this a problem with the starter? You state that occasionally you have to reset the radio stations.
    Something is causing you to lose complete power to the vehicle. If it was only the starter, you wouldn't have issues with the stereo.
    I would start simple and check the body grounds.
  11. Jul 16, 2016 at 12:00 AM
    wilcam47
    Will
    Bourbon state
    that old of a vehicle and he already replaced the battery...the starter drawing too much amperage could make it seem like it was dead/no power.
  12. Jul 16, 2016 at 12:25 AM
    koditten
    Kirk
    Central Michigan
    Naah, that dog won't hunt. Problems with Toyota starters are never progressive. It either works or it doesn't. Change the contacts and the starter is as good as new. I've never heard of the windings shorting out.
    His starter would have to be drawing the battery down to less than 9 volts to make the stereo lose its memory.
    I wonder if that positive wire that feeds the fuse block is bad?
  13. Jul 16, 2016 at 1:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Poor grounds along with pitted contacts trying to draw through very small points .
    Just all round old age combining to cause the buss voltage to drop below the threshold voltage to lose the presets as well as not crank
    Then without being hands on it is all just a guess .
  14. Jul 16, 2016 at 11:26 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    This thread is 7 years old! Hopefully he figured it out by now.
  15. Jul 16, 2016 at 11:46 PM
    koditten
    Kirk
    Central Michigan
    LOL. I feel stupid.
  16. Jul 20, 2016 at 11:27 AM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    When I rebuilt my engine it did that. Forgot to connect the ground wire from the valve cover to the fire wall. As soon as I connected it, the engine turned over
