Clicking/Knocking on front drivers side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bleucheese87, Aug 24, 2021.
  1. Aug 24, 2021 at 11:24 AM
    Bleucheese87
    Bleucheese87 [OP] Member
    Kyle
    2021 Army Green Tacoma TRD Sport
    Hello, I was wondering if any of you have experienced a Clicking noise in the front drivers side of the truck. Mostly happens when i back into my driveway or sometimes when slowly turning in neighborhoods. The truck is pretty much brand new, havent even hit 5k miles yet.
    Thanks for any information.
  2. Aug 24, 2021 at 11:29 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I have a bad cab mount bushing on the drivers side. It makes a pop or clicks when I go over speed bumps.
    bshammer0 and Bleucheese87[OP] like this.
  3. Aug 24, 2021 at 11:35 AM
    AbdullaJaafari
    AbdullaJaafari Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    I inspected every bushings on the front end and I went absolutely mad as the car is still new but making a terrible 30 year old car noise.
    Turned out to be the cab mount near the radiator support.
    It was an easy replacement. I didn't remove the grill or bumper. I only removed the lower portion of the fender liner and managed to get a direct look at the nut and bolt from the bottom.
    A good video showing what you're looking for: https://youtu.be/ch8f-uEy2Ok?t=44
    A nice thread about it here: https://www.tacomaworld.com/threads...all-now-with-pictures-and-a-video-too.432885/
    The bushings for the front are Energy Suspension 9.4101G
    Bleucheese87[OP] and 9th like this.
  4. Aug 24, 2021 at 11:40 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Clicking when turning is a CV axle noise which at 5k is crazy. Try a slow locked steering wheel left, and then right and see if the sound is typical on both sides. If it's isolated to one side, take it in and have them look at the axle in the front. Or...reach up and grab the axle shaft and try to shake it out of the truck. You'll know if it's junk.
    Zim
    Bleucheese87[OP] likes this.
  5. Aug 24, 2021 at 11:48 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Mine does it when I first pull out of my driveway after starting it then doesn't do it again. Idk idc at this point
  6. Aug 24, 2021 at 11:59 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Well, i've got zero noises from my 2020...most solid built truck ever owned.
  7. Aug 24, 2021 at 12:09 PM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Tacoma Making Pop Sound
  8. Aug 24, 2021 at 1:53 PM
    ryanvar42
    None
  9. Sep 27, 2021 at 12:27 PM
    Bleucheese87
    Kyle
    Hello everyone,
    I took my truck back to the dealer today to ask about this noise. Apparently its an issue with the way the body sits on the frame that causes a rubbing. The guy working there told me he expects it to be a recall soon as they're seeing more and more of these all the time. Hopefully this helps anyone else who hears the same noise.
  10. Sep 27, 2021 at 12:40 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Yes, the cab mount bushings mentioned by posters above.
    Do what you want, but if you're going to let the dealer off the hook until a recall is issued...you're going to be waiting a long time.
    Fix it yourself with upgraded material or make them fix the defective bushing...with another defective bushing that will likely fail too.
    Beerpayzdabillz likes this.
  11. Sep 27, 2021 at 1:28 PM
    Bleucheese87
    Kyle
    I’m not letting them off the hook, they’re fixing it as we speak. I got a loaner car for 1 day. I was saying there WILL be a recall for the issue.
