Clicking noise when front end dips down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevC, Oct 2, 2017.
  1. Jul 16, 2019 at 1:08 PM
    #61
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    What exactly in the strut assembly failed...???
  2. Oct 23, 2020 at 1:15 PM
    #62
    Johnstacoma621
    Johnstacoma621 New Member
    Dominick
    2018 tacoma trd or
    So here is what i found which i believe is the exact issue , take a rubber mallet and hit the cv joint cup on the side going into the front differential from the bottom ( leave the truck on the ground, do not jack it up) . You will hear that exact clicking sound . Im not sure there is a fix for this but i will be taking my axles out this weekend to inspect the shafts
  3. Oct 31, 2020 at 2:47 PM
    #63
    thumpper
    thumpper Well-Known Member
    Bob
    Nebraska
    2008 Taco
    Havent been following this thread like I should but have you checked your body mounts upfront befor you go through all thst work? If nkt may want to check replace those be much easier. (That is what was wrong with mine) I swore it was a front axle too but wasnt.
