Climate control face removal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Dec 12, 2011.
  1. Dec 12, 2011 at 8:22 AM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys I need to replace a bulb from my climate control dash. I have a question what tool do I need to remove the climate control face any tips?? I dont want to break anything thats why I ask. Any help will be much appreciate it.
  2. Dec 12, 2011 at 8:27 AM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I use a screwdriver and pry gently behind the edges after you take the knobs off.
  3. Dec 12, 2011 at 8:46 AM
    Hektor
    Texas
    Cool so its not tht hard at all?
  4. Dec 12, 2011 at 8:50 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I tried with a flat head screwdriver and and allen wrench, i felt like i was going to break it. particularly in the upper left corner, that part wouldn't release, then i found a hooked pick tool, snuck it up and back into the corner and it popped out easy.
    Looked something like this.
  5. Dec 12, 2011 at 8:54 AM
    Hektor
    Texas
    Thanks you Sir I'lI be heading to wally world to pick up that tool.
  6. Dec 12, 2011 at 9:07 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    x2 screwdriver worked on mine, it popped off pretty easy when I changed out the stereo.
  7. Dec 12, 2011 at 9:11 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Are you sure it is not just module? Mine has a different bulb go out all the time and you tap the module and they come back on. I have checked the connections and everything but cannot seem to track down the problem. Anybody else have this issue?
  8. Dec 12, 2011 at 9:47 AM
    Hektor
    Texas
    I believe its the bulb since its only the bulb at illuminates the ac speed control, the other two controls light up no problems there.
  9. Dec 12, 2011 at 9:52 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I just put my fingers in the hole thats behind the knobs and it just pops out...no tools needed, its pretty forgiving and i doubt it will break just make sure you pull evenly on each side
  10. Dec 12, 2011 at 10:00 AM
    Hektor
    Texas
    Mmmm really I might have to give it a shot. As far as breaking someone mention tabs that hold it might break?? That is what worries me.
  11. Dec 12, 2011 at 11:02 AM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    Yes, my middle knob light and whatever else is connected to it comes on intermittently. Annoying and can't find a rhyme or reason behind why it does what it does.
  12. Dec 12, 2011 at 11:06 AM
    RAT PRODUCTS
    Farmington, MN
    I've popped mine off several times without breaking, even being a little rough on it. Now mine comes out just with my fingers, like someone else mentioned. No tabs broken, though.
  13. Dec 12, 2011 at 11:53 AM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I dont remember seeing any tabs back there and if there are any then id say i havent broken any while pulling on it pretty hard.... and it always goes back on the way it came off and isnt loose or anything so id say you will be fine.
  14. Dec 12, 2011 at 8:43 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure what year Tacoma you have, Hektor, but mine came apart pretty easily when I installed my stereo. The only word of caution I'd offer is that the knobs each had a small, semi-circular metal "sleeve" required to hold it them on the control shafts. Without the sleeves between the knobs and shafts, the knobs would would fall off. Two of my sleeves remained in place, while the third fell off when I removed the knob. Luckily, I saw it go and quickly retrieved it...
  15. Dec 12, 2011 at 9:00 PM
    Hektor
    Texas
    Thanks for the heads up, btw I have a 2003 did you used the hook tool as well?
  16. Dec 12, 2011 at 9:02 PM
    Norton
    A small, flathead screwdriver worked for me, but I did proceed carefully...
  17. Dec 12, 2011 at 9:06 PM
    Bo Rocks
    Bo Rocks Well-Known Member
    Brian
    Southern CA
    2006 4x4 Long Travel
  18. Dec 13, 2011 at 6:42 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    same here... piece of cake
  19. Dec 13, 2011 at 7:07 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  20. Dec 13, 2011 at 9:03 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I just use my leatherman. It seems like the perfect interior modification tool...especially on the fly since it's always on my belt.
