Climate Control LED Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bhwang, Dec 3, 2012.
  1. Dec 3, 2012 at 6:41 PM
    Bhwang
    Bhwang [OP] Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Hey so here is my problem, my climate control lights do not work for some weird reason, I have new bulbs and have tested them and they work and no light emits from the climate control cluster so it is kind of hard to change the heat at night. BTW 2009 Tacoma DCSB 6spd.
    So is it possible to hook up 2 amber LED under the stereo dash to shine down on the climate controls from the clock wires or closer ones, if so which wires would I use ? Any help would be appreciated.
  2. Dec 3, 2012 at 6:49 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I saw a thread a long time ago with that exact product. Can't remember what it was called. Give me a minute and I'll see if I can find it.
  3. Dec 3, 2012 at 6:50 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge.
  4. Dec 3, 2012 at 6:51 PM
    NelsonTacoma
    Tucson, AZ
  5. Dec 3, 2012 at 6:53 PM
    vstrom
    vstrom Well-Known Member
    Check and make sure the fuse isn't blown.. I believe the cluster and taillights share the same fuse.. happened to me.
  6. Dec 3, 2012 at 6:54 PM
    AZBACKCOUNTRY
    Doug
    I just installed mine today. Works great and totally lights up the climate controls.
    Az
  7. Dec 3, 2012 at 6:56 PM
    Bhwang
    Josh
    Canada
    Tacoma
    Checking out there website it looks like a neat product, but like I said I dont think there is power coming from the wires for the lights on the climate control so therefore this hookup would not work, so I am hoping to hook the clock lights/power or the dash lights. Just need to know what wires to hook up too.
    Or was my truck which is a 2009 Tacoma not have the illuminated climate control lights ?
    I have checked the fuses over and over and all are good
  8. Dec 3, 2012 at 7:09 PM
    NelsonTacoma
    Tucson, AZ
    Are you sure the bulbs just aren't burned out? That is a common problem on these trucks.
  9. Dec 3, 2012 at 7:30 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2015 Tundra Double Cab
    Kings:Camburg:BFG
    OP States new bulbs :)
  10. Dec 3, 2012 at 7:31 PM
    NelsonTacoma
    Tucson, AZ
    Guess I should read more.......:(
  11. Dec 3, 2012 at 7:32 PM
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    99% of the time i just read titles :anonymous:
  12. Dec 3, 2012 at 7:33 PM
    Bhwang
    Josh
    Canada
    Tacoma
    Both bulbs are new and I have tested them out of the truck with a power battery pack and they work fine, so now my plan is to drill 2 holes below to the stereo deck where that fly design thing would mount and wire them to turn on with the dash lights or when the other interior lights turn on, any help on where to wire too would be great, thanks
  13. Dec 3, 2012 at 7:33 PM
    NelsonTacoma
    Tucson, AZ
    I thought I was the only one that did that. I guess that's a side-effect of spending to much time on TW.
  14. Dec 3, 2012 at 8:02 PM
    Bhwang
    Josh
    Canada
    Tacoma
    HAHA thanks guys !!!!
  15. Dec 3, 2012 at 8:13 PM
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    OP I'm having the same problem :(
  16. Dec 4, 2012 at 4:45 AM
    Bhwang
    Josh
    Canada
    Tacoma
    Bump for anything that can help
  17. Dec 4, 2012 at 10:11 AM
    Bhwang
    Josh
    Canada
    Tacoma
    Have your climate control lights ever worked?
  18. Dec 4, 2012 at 2:03 PM
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    yeah they went out after i took the unit out a few times installing my radio
  19. Dec 14, 2012 at 8:18 PM
    Zildjian
    Zildjian New Member
    Nick
    Pasadena, CA
    06 Tan, 4x4
    That recently happened to me. I tried to switch the shifter light with an LED and now my AC lights including the shifter light dont have power. They have always worked so i'm guessing I blew a fuse, but i checked all the fuses and they look good. Any ideas...
