Clock Problems - Strange
Discussion in '1st Gen. Tacomas (1995-2004)' started by cshoe98, Nov 19, 2007.
  1. Nov 19, 2007 at 7:26 PM
    cshoe98
    cshoe98 [OP] Member
    Chillicothe/Athens Ohio
    '98 SR5
    Dirt/Snow off road tires, Westin Bed X-Tender, Rain & bug guards, Nerf bars.
    So my stock, in dash clock has been having some troubles. Every now and then I have to push on the faceplate of the clock for it to show up.... Like I will start my truck up and the clock does not show up. As if its broke or something. When I push lightly on the faceplate the numbers start to show up, the harder I push the darker the numbers get.
    Its really strange...and hard to explain.... Wondering if any of you have had the same problem?
  2. Nov 19, 2007 at 8:17 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    never heard of the problem but you may be able to fix it by taking clock out of the dash and seeing if the backing is loose... (like where it plugs in)
  3. Nov 19, 2007 at 8:52 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    I agree, it sounds like you would have some sort of a loose connection. If you find that all the wires are connected correctly I would check to see if you might possibly have a broken solder.
  4. Nov 25, 2007 at 4:07 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    check on ebay for a new one
  5. Dec 18, 2007 at 8:54 AM
    A1CGuches
    A1CGuches Oregon Alliance: Founder
    DMAFB, Arizona
    01 Taco
    Custom snorkel/intake, 6" lift, 35X12.5 mt's, flowmaster 40 seriers, performance clutch, custom skid plate, grille, everything is black on green, rotrex supercharger, 7th injector kit, urd short throw shifter, thorely header, kks speed limit defender...and more to come
    Or go to the Wal-Mart and get a ten dollar wrist watch...then like ive said before mount some toggle switches in its place.
  6. Dec 18, 2007 at 9:53 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Good idea! !! You can't see the dang things in the daytime anyway:D
    Don G
  7. Dec 18, 2007 at 12:26 PM
    Taco95
    Taco95 Active Member
    Ha ha atleast yours isn't like mine! Mine use to not work at all, i thought it was completely broke. Then one day i started it up and it came on. well about 30 mins later it went out and it doesn't come on unless you hit the clock LOL i kinda like it, keeps me occupied while im driving.:D
    its not really something i can complain about, like someone else said just get a wrist watch you can't see the damn things anyways.
  8. Dec 18, 2007 at 12:31 PM
    A1CGuches
    DMAFB, Arizona
    01 Taco
    haha yeah mine worked for about ten minutes after i bought it then it went bad...so i mounted the toggle switch for my auxillary back up lights there.
  9. Dec 18, 2007 at 1:00 PM
    cshoe98
    cshoe98 [OP] Member
    '98 SR5
    Yeah I have to hit mine pretty much to get it to work...
    My CD player I had installed shows the time so I am not that worried about it... just found it really STRANGE.
    Mounting a switch there though is a good idea.... I might have to do that.
  10. Dec 18, 2007 at 1:33 PM
    A1CGuches
    DMAFB, Arizona
    01 Taco
    If you have any questions on what to do or remove when you do it just ask.
  11. Jun 25, 2013 at 5:01 PM
    TPain
    TPain Boss
    Tanner
    Asheville, NC
    01 Supercharged
    I know this is almost a 6 year old thread but was this problem ever fixed? My clock does the same exact thing.
  12. Jun 25, 2013 at 10:17 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    bump mine too
