CLOSED -- Any Softopper Model GB and BS Thread
Discussion in 'Automotive Group Buys' started by tonered, Oct 28, 2019.
  1. Nov 1, 2019 at 2:51 PM
    #141
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    @T.A.C.O.M.A
    Other than your username being hard a balls to tag, you might wanna think about pulling the trigger.
    :cheers:
  2. Nov 1, 2019 at 3:01 PM
    #142
    tonered
    tony
    Lynnwood, WA
    Hey, Folks.
    This puppy is :deadhorse: . Thanks for looking!
    To the five other folks who took the risk, I just got a surprise message that the killer folks at Softopper processed the discount for us. Friggin' WOOT!
    This GB is Closed!
  3. Nov 1, 2019 at 4:18 PM
    #143
    cloudr1pper
    cloudr1pper Well-Known Member
    @northshore @tonered thanks a ton guys, appreciate it!
    Also, kudos to Softopper for processing the discount anyway! Was stoked when I received their message. A+!!
    uploadadventure and tonered[OP] like this.
  4. Nov 1, 2019 at 5:43 PM
    #144
    tonered
    tony
    Lynnwood, WA
    You're welcome!
    Same here. My mouth fell open.
    Almost done with the installation.
    uploadadventure likes this.
  5. Nov 1, 2019 at 7:17 PM
    #145
    tonered
    tony
    Lynnwood, WA
    I'll get some better pics.
    I recommend pulling the rails, protecting the paint, and sealing. I had some wear spots from my tonneau and jumping over the side.
    I'll get some better shots in the morning.
    A couple installation things. The alignment pic they show for the rails is a 2nd Gen. Sight to the bed itself, not the header rail. Interestingly, the screw-in snaps went in the header rail. I was expecting them to go into the composite bed itself. That was a pleasant surprise.
    The Softopper is much nicer than expected and works great on a quick highway run.
    You guys are gonna love it.
    Have a good one!
    Rock Lobster, northshore and dilbert like this.
  6. Nov 1, 2019 at 7:36 PM
    #146
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Looks great!
    Park it in the sun tomorrow and any wrinkles from being folded up will go away.
    tonered[QUOTED][OP] likes this.
  7. Nov 1, 2019 at 7:45 PM
    #147
    tonered
    tony
    Lynnwood, WA
    Thanks. Great tip. I will do that.
    dilbert[QUOTED] likes this.
  8. Nov 1, 2019 at 7:52 PM
    #148
    dilbert
    dilbert AI Member
    PNW
    If your going to camp back there these help with closing the tailgate from inside.
    And you can make like Buffalo Bill and tuck it...
  9. Nov 1, 2019 at 8:19 PM
    #149
    tonered
    tony
    Lynnwood, WA
    Fava beans!
    Does tucking work that well? No need for the hook tape?
    That loop is a great idea also. :cheers:
    Thanks again!
  10. Nov 1, 2019 at 8:31 PM
    #150
    dilbert
    dilbert AI Member
    PNW
    I've tucked it since it was new. At first I intended to get some xpel to go across the top of the tailgate for protecting the paint when leaving it un-tucked, but that never happened. I've never used the hook tape on the tailgate.
    Surprisingly it stays dry inside, even when tucked.
  11. Nov 1, 2019 at 8:34 PM
    #151
    tonered
    tony
    Lynnwood, WA
    Well, hook tape coming off. Hahahaha!
    Skydvrr likes this.
  12. Nov 1, 2019 at 8:44 PM
    #152
    dilbert
    dilbert AI Member
    PNW
    Skydvrr and tonered[QUOTED][OP] like this.
  13. Nov 2, 2019 at 12:02 AM
    #153
    tonered
    tony
    Lynnwood, WA
    Yes. I am sealed back there. We'll see what happens. A new strip of hook is no big deal.
    Lighting is on my mind. I have a bunch of lights from HF and others. We'll see what comes up.
  14. Nov 2, 2019 at 11:43 AM
    #154
    tonered
    tony
    Lynnwood, WA
    Hey, Folks.
    No pics today. I had to do stuff with the daughter for school.
    I did readjust the tension on the topper. The middle hole on the bracket feels too stiff in the cold since it takes too much effort to snap it. I dropped it to the lowest hole. Just a bit of tension to snap it and no flapping on the highway.
    Dropping the top is a freaking breeze.
    :cheers:
  15. Nov 2, 2019 at 12:00 PM
    #155
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Thanks tony! Glad I got it. I dont think I’m gonna add the front snaps / Velcro, or in the rear. Are your mounting rails rolled inwards?
    tonered[OP] and uploadadventure like this.
  16. Nov 2, 2019 at 8:28 PM
    #156
    cloudr1pper
    @tonered so did you mount the sides to the raw metal bedframe and not the plastic bed cover? Did you not use the clamps for the trac system either?
    thanks!
    tonered[OP] likes this.
  17. Nov 2, 2019 at 8:37 PM
    #157
    tonered
    tony
    Lynnwood, WA
    Sorry for the confusion. I was snapping pics when I could and racing daylight and dropping temps. The rail caps went back on over the caulk. I was just protecting the metal and ensuring a water seal even though I only ever got water in by the front corners. Those are sealed now also.
    Just looking for a dry camping setup.
    Compared to my tonneau clamps, the Softopper clamps are simpler and way beefier.
    My only change from the instructions is using @dilbert 's recommendation to tuck the rear flap instead of using the hook tape on the tailgate.
    I meant to take some pics today, but it was a good, long day out with the fam. After some runs on the highway and around town, it is everything that I wanted and more.
  18. Nov 2, 2019 at 8:39 PM
    #158
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I feel like those clamps roll the square tubing.
  19. Nov 2, 2019 at 8:43 PM
    #159
    tonered
    tony
    Lynnwood, WA
    Interesting. You don't need much more torque than flattening out the lock washer and a bit of compression on the foam. That is plenty for it all to bite on the texture of the rail cap.
    I went with 12in from each end of the Softopper rails. That put them in a nice spot and seemed to get a bit of compression in the middle also?
  20. Nov 2, 2019 at 8:48 PM
    #160
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I got too much shit going on With my rails to measure. But I tried to split it in 3rds. I leveled the rails out and tightened the clamps and they're rolled inwards
