**CLOSED**ARB Compressors - Group Buy
Discussion in 'Automotive Group Buys' started by ramonortiz55, May 24, 2017.
  1. Jul 24, 2017 at 8:13 AM
    #461
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
  2. Jul 24, 2017 at 9:26 AM
    #462
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    30 minutes at 72 degrees.. I wonder how the exterior temp impacted duty time
    Sleipnir[QUOTED] likes this.
  3. Jul 24, 2017 at 9:27 AM
    #463
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    it was hot as balls as I ran it, mainly humid really.
  4. Jul 24, 2017 at 9:29 AM
    #464
    TSki
    Tyler
    Salmon, Idaho
    I found the chart based on 72 degrees.. I wish they had a version for hotter temps
    stronghammer[QUOTED] likes this.
  5. Jul 24, 2017 at 11:24 AM
    #465
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    ARB offered to send me a new hose. They also said mine is rebuildable, but I told them I'd rather not do that and just get a new one and send this one to them.
    Superman910 likes this.
  6. Jul 24, 2017 at 11:50 AM
    #466
    Arlaghan
    Arlaghan Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    Looks like I'm late for the party. I used it for the first time (beyond testing) this weekend to fill up a kiddy pool. It got pretty hot, but not so much I couldn't disconnect the hose when I was done. Definitely something I will be on the watch for.
    stronghammer likes this.
  7. Jul 24, 2017 at 12:04 PM
    #467
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Nice! Now get yourself that steel braided line.
  8. Jul 24, 2017 at 1:02 PM
    #468
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    The first time I used my ARB CKMA12 Heavy Duty Air Compressor, it was very hot. I used it to air up my 285 size tires from 20 psi to 38 psi. After the first two tires, I felt it getting warm...so I paced out the other two tires.
    Afterwards, I ordered a Steel Braided Leader Hose and installed it from the air compressor to the line that I run to the bed of the truck. It provides about 10" distance from the hot air compressor.
    This is the one I used:
    https://www.amazon.com/gp/product/B00EVQI9YS/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
    So far, so good...it's been about six months since I've installed it, and I've used my air compressor a few time since.
  9. Jul 24, 2017 at 1:06 PM
    #469
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    thank you. I'll be getting one as well. Do you still pace yourself on the tires?
  10. Jul 24, 2017 at 1:55 PM
    #470
    seoulja99
    E.J.
    Oahu
    Negative. The steel braided leader hose works like a charm. I do want to wrap it with either shrink wrap or possibly some heat resistant hose/cover so it doesn't burn the air intake tube that the leader hose is very close to. It's not touching anything usually but, don't want to take the risk of it making contact while I'm using the air compressor and melting a part of the air intake tube.
  11. Jul 24, 2017 at 3:34 PM
    #471
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I guess this means I need a steel enclosure for mine, and not in the same compartment as my battery
  12. Jul 29, 2017 at 7:05 PM
    #472
    ShemRahBuck
    ShemRahBuck Well-Known Member
    Buck
    Eastern California
    2017 TRD Pro
    Ughhh. I really need the dual compressor and don't want to fork up the dough. Let's bring back another group buy!
  13. Jul 30, 2017 at 12:57 AM
    #473
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Shop around... I was in the same boat yesterday and managed to pull the trigger on a dual that was, what i assume, barely over GB price...
    ShemRahBuck[QUOTED] likes this.
