Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Mar 12, 2016 at 8:13 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Two more added upon their request!
  2. Mar 12, 2016 at 8:27 AM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    I was installing rock lights last night and took a look at my CB. Man that thing is looser than a $2 whore! You can see that it's sitting about a 1/2" low and got probably close to 2" of vertical play out of it by pushing up.
    nfs257 and 12TRDTacoma[OP] like this.
  3. Mar 12, 2016 at 8:29 AM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    We are at 10 people. Cmon guys!
    12TRDTacoma[OP] likes this.
  4. Mar 12, 2016 at 8:31 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Well I was going to until I saw Long Bed would not be easy to do.
  5. Mar 12, 2016 at 8:39 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    @nfs257 has the McMaster one on a dclb which appears to sit about the same height as this one and op has a dclb too. Ask them if it's a problem.
    12TRDTacoma[OP] and nfs257 like this.
  6. Mar 12, 2016 at 8:42 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks I was just going by what nd4spdbh quoted, I am not handy at all and if this is going to require further modding. Takes me out of the game.
  7. Mar 12, 2016 at 8:45 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    Gotcha. Mines a dclb and I'm gonna go for it cuz fuck replacing the stock one every 2 years. Hopefully it's not a big deal but I take it as a good thing that its been done to two trucks already and they don't seem to have issues with it.
  8. Mar 12, 2016 at 8:47 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    @12TRDTacoma how much would you say this drops the driveshaft on a dclb? Best guess
  9. Mar 12, 2016 at 8:50 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I will keep an eye on this as this looks like a nice mod to do.
  10. Mar 12, 2016 at 8:51 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
  11. Mar 12, 2016 at 8:52 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Surprised they don't make one that uses the factory bolt locations though?
  12. Mar 12, 2016 at 8:56 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    Its because this CB is for a Ford ranger which happens to be the same diameter as our driveshafts so I guess the ranger mounting is probably set up a bit differently.
  13. Mar 12, 2016 at 8:57 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    :thumbsup:
  14. Mar 12, 2016 at 10:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I had that much play out of mine as well. That's what prompted me in replacing it.
    More more more!!
    Yeah that's exactly why I did mine. I don't want to touch it pretty much ever again.
    Depends on how thick of plating you use, but I used 1/8" on mine and it dropped it 1/8".
    Not by much honestly.
  15. Mar 12, 2016 at 10:41 AM
    #35
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I think you may have got that backwards, DCLB should be just fine... It's what the OP has. Only thing needed is a small backing plate so the bearing can't slip out of that half round frame (I'm guessing on the ford it bolts up to a solid surface and isn't needed for them).
    I'll be all over this if I get any vibes from the CB post lift. It's a bit early to tell with not many testers yet or a lot of test time, but it looks like this could be a plug and play solution and tons of people on here have CB vibes. Could turn into a popular fix like the ECGS bushing.
    @12TRDTacoma if these are custom made by the company do you think they would end up making a completely bolt on version for the Tacoma if there is a lot of interest? I don't see making a backing plate as a problem for myself but others may not have the tools or know how.
  16. Mar 12, 2016 at 10:46 AM
    #36
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks James, when I first put my lift in I did what I always did and used shims, and the carrier bearing drop kit. Then finding out from ICON that I should not need shims I threw everything off by 3 degrees and had a horrible vibe. Took all the shims out and the carrier bearing drop kit. But in the month or so that I havdthe shims in and changed the driveline by 3 degrees it actually seems to have taken a few chunks out of the rubber on the carrier bearing. So I will be watching this as I hope it will be a longtime fix. As I still have a vibe in it with or without the carrier bearing drop kit in.
  17. Mar 12, 2016 at 11:07 AM
    #37
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    No problem, I'll be keeping an eye on this one too. That sucks about the chunks being taken out, hopefully not enough missing that it's lacking support now. I'm far from an expert on the topic but it does seem like getting the driveline angles right is the biggest factor. I'm guessing this bearing takes care of any remaining vibes by reducing the amount of play / slop in the CB. I haven't taken a good look at mine but I'm sure the rubber allows for a pretty good amount of movement.
  18. Mar 12, 2016 at 11:11 AM
    #38
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    The strange part is I only get a little vibe going up a hill.
  19. Mar 12, 2016 at 11:23 AM
    #39
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Crom likes this.
  20. Mar 12, 2016 at 11:30 AM
    #40
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    It drops the driveshaft by about 2 inches. Just look where the stock cb would attach to the frame... at the centerline of the cb, this one mounts on the upper edge. Its not a big deal but just understand it does drop it. There are some easy ways you could get it to mount at the same height if you really want it at the same height.
