Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Mar 28, 2016 at 9:28 PM
    #541
    Springs719
    Springs719 Well-Known Member
    Brett
    08trdoffroad
    Cool, will put a order in tomorrow for one thank you
  2. Mar 28, 2016 at 9:31 PM
    #542
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Just keep in mind the work to place it on the shaft and then mount it on the truck.
    12TRDTacoma[OP] likes this.
  3. Mar 28, 2016 at 9:46 PM
    #543
    Springs719
    Brett
    08trdoffroad
    I have read through half of this thread and it doesn't seem to bad. Do you have any concerns about installing it.
  4. Mar 28, 2016 at 9:47 PM
    #544
    nfs257
    DFW
    She gone
    Not really since I have a pillow block bearing and have cut up my mounting point lol
  5. Mar 28, 2016 at 9:50 PM
    #545
    nfs257
    DFW
    She gone
  6. Mar 28, 2016 at 9:53 PM
    #546
    Springs719
    Brett
    08trdoffroad
    So would you say a one pice would be better. Have a shop that can make one for 425.
  7. Mar 28, 2016 at 9:55 PM
    #547
    nfs257
    DFW
    She gone
    Not at all. At least for my application since Im a double cab long bed. I know at one point Tom Woods wouldnt make one for it cuz the shaft is too long. I changed my stuff around due to angles and not due to the bearing itself.
  8. Mar 28, 2016 at 10:03 PM
    #548
    Springs719
    Brett
    08trdoffroad
    I called one company in town and they told my they wouldnt because the shaft is to long. Then called another shop someone referred me to and he has a double cab long bed too. The shop said they can do it but beff it up so it will work. I have a dcsb so I don't fucking know lol. 75 dollars sounds better than 425. Don't mind about modified have a grinder an can get the oxy-acetylene from work if need be.
  9. Mar 28, 2016 at 10:05 PM
    #549
    nfs257
    DFW
    She gone
    Shouldnt need either if youre pretty much stock. Just put it on. And then use a piece of metal to back it with, if needed to drop mount it on way. If want it closer to stock mount it the other way with a couple of spacer like shown on the first post.
  10. Mar 28, 2016 at 10:09 PM
    #550
    Springs719
    Brett
    08trdoffroad
    Ordered 885 and bilsteins with the darker leaf pack should be in this week so I can do the bearing at the same time as the lift.
    nfs257[QUOTED] likes this.
  11. Mar 28, 2016 at 10:11 PM
    #551
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Buy once cry once. You'll be good to go in doing it all at once. It'll take a little bit longer, but it's SOOOO worth it!
  12. Mar 28, 2016 at 10:18 PM
    #552
    Springs719
    Brett
    08trdoffroad
    Thanks man for the input. How hard is doing the needle bearing thinking about doing that too. I have a jerky movement when accelerating or letting off the gas. Doesn't help with the boost I have too.
  13. Mar 28, 2016 at 10:27 PM
    #553
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What needle bearing?
  14. Mar 28, 2016 at 10:45 PM
    #554
    Springs719
    Brett
    08trdoffroad
    My bad thinking of the wrong thing. Thought I read this company sells a kit for it. Could be wrong
  15. Mar 28, 2016 at 11:07 PM
    #555
    nfs257
    DFW
    She gone
    Pretty sure that's URD.
  16. Mar 29, 2016 at 4:57 AM
    #556
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ECGS front clamshell (differential) needle bearing?
    Springs719[QUOTED] likes this.
  17. Mar 29, 2016 at 5:10 AM
    #557
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Is there a DIY tutorial for how to install/replace this?
  18. Mar 29, 2016 at 10:32 AM
    #558
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Search up how to change u joints and the carrier bearing. Not bad at all with the know-how and a u-joint tool rented from a place
  19. Mar 29, 2016 at 10:51 AM
    #559
    ItalynStylion
    Steven
    DFW, Tx.
    Got a call from them today. They said they would try and ship next week. I hope that's accurate! :D
  20. Mar 29, 2016 at 10:54 AM
    #560
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Is this for the first set of people, or the second?
