Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Apr 7, 2016 at 10:52 AM
    #681
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Might only be a 1st gen problem
  2. Apr 7, 2016 at 1:14 PM
    #682
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    We have already established that the big washer cover thing was not necessary as the bearing is a sealed unit long ago.
    alphabravo and Unchained 5150 like this.
  3. Apr 7, 2016 at 1:25 PM
    #683
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    When in doubt popcorn is always a safe bet haha
  4. Apr 7, 2016 at 1:25 PM
    #684
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  5. Apr 7, 2016 at 2:04 PM
    #685
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    hmm, missed that...
  6. Apr 7, 2016 at 2:47 PM
    #686
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Since this is post is almost at 700, you're forgiven. Dam this one blew up fast
  7. Apr 7, 2016 at 3:24 PM
    #687
    lonewolf1911
    lonewolf1911 Where's my wolf pack?
    JT
    WA
    12' DCSB TRD OR 6SPD
    I lost track...
    Put me down for the 3rd list please.
  8. Apr 7, 2016 at 3:34 PM
    #688
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Thank you and now the REAL test of how competent of this replacement will be how quickly I can remove 4 bolts, disconnect the carridan flange from the center bearing flange, unkey the key, remove the 134 ft/lb nut, remove the washer cover thingy, put it back together.
    @Digiratus
    Still need steel flat bar?
  9. Apr 7, 2016 at 5:03 PM
    #689
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  10. Apr 7, 2016 at 5:07 PM
    #690
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't rush man. That's how mistakes happen. It's not worth it. 10 minutes of time save is not worth 45 of fixing the mistake which happened from trying to save 10 minutes.
  11. Apr 7, 2016 at 6:12 PM
    #691
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    True
  12. Apr 7, 2016 at 8:57 PM
    #692
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, save me a piece. Thanks.
    Not sure when I'll need it tho. At the rate things are going. It might be a while.
  13. Apr 9, 2016 at 12:02 PM
    #693
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Got mine in today and after someone inspecting mine, it was said I don't need it. But I might just get it installed anyway, as Toyota's sucks
    scottalot likes this.
  14. Apr 9, 2016 at 1:57 PM
    #694
    zeekevin
    zeekevin Well-Known Member
    San Diego
    Randomly got mine in the mail today
    MTopp likes this.
  15. Apr 9, 2016 at 2:19 PM
    #695
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interestingly enough the backstory on my ordeal went, after I brought in my driveshaft over to the shop to get it installed, they looked at my new one and said that it didn't seem like it would be heavy duty enough for the truck to handle.
    After the install and all went mounted up, I have NEVER been more happy with a mod before. Moral of the story is that looks can be deceiving (same can be said for OE's what appears to be oversized and stout CB. Haha yeah right, stout...) and don't always take the first piece of opinion or advice you are given and take it as gospel.
    Very nice! :thumbsup:
    Yetimetchkangmi and MonkeyProof like this.
  16. Apr 10, 2016 at 5:38 AM
    #696
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Well we'll see if it's heavy duty enough by how long it lasts mileage wise. Oem or aftermarket oem styles can last from 15k to 100k miles.
  17. Apr 10, 2016 at 5:47 AM
    #697
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What part numbers are people using to replace the U Joints if needed as well??
  18. Apr 10, 2016 at 11:19 AM
    #698
    MTopp
    05 SR5 4x4
  19. Apr 10, 2016 at 11:19 AM
    #699
    MTopp
    05 SR5 4x4
    I bought moog replacements though. Spicer is probably better.
  20. Apr 10, 2016 at 11:23 AM
    #700
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Both links say they don't fit my 2015 which I am sure it's inaccurate. And I thought our trucks only had 3 U Joints
