Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Jul 14, 2016 at 1:06 PM
    #1041
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I bought it used with 75k on the clock so it was an unseen issue.
    Even if I took a screwdriver and moved it inbetween the yokes of the un-joint, there wasn't any movement.
    Yes, I agree on the greasing but if you look closely, that shaft hole is completely filled with debris, I took a pick to unclog it.
    No grease was going to make it thru there!
    MTopp[QUOTED] likes this.
  2. Jul 14, 2016 at 3:12 PM
    #1042
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I know this is KINDA off topic, but it's another option now that the bearing s full price.
    I'm also going to be putting my shaft and bearing in the classifieds soon. First shot to those reading this thread Send me a PM though. Don't want this to turn into a for sale thread...
    I picked up the new one piece driveshaft and threw it in. $573 all new.
    The shaft is 1/8 inch thick steel. Look at the difference in the slip joint diameter. I didn't measure, but it's noticeable.
    I also had them use a slip joint that was splined the entire length instead if the normal couple of inches. Hopefully this will keep any high speed wobbles at bay.
    The slip joint is also greasable
    Installed
    Here's the shops info for anyone who's local. I also saw a bunch of shafts ready to ship...
    DrFunker, Drainbung, samiam and 4 others like this.
  3. Jul 23, 2016 at 8:16 PM
    #1043
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Looks great
  4. Aug 1, 2016 at 8:53 AM
    #1044
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Hey Guys, my carrier bearing (center support bearing) is pretty shot, I've been looking at this bearing for awhile now. But in searching around online I came across another bearing for a Ranger that's very similar, made by Spicer and much less expensive. It looks like the bearing ID is correct. Has anyone tried this bearing?
    http://www.jegs.com/i/Spicer/094/21...193344547511&gclid=COa0q6TEoM4CFVKEfgodcn4G4w
  5. Aug 1, 2016 at 12:22 PM
    #1045
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I believe the CB that this thread is about is actually one from a Ranger anyway. So I'd imagine they are very similar if not identical.
    eccracer104 likes this.
  6. Aug 1, 2016 at 12:28 PM
    #1046
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I think mine will be up for sale soon just want what I paid for it
    nfs257 and eccracer104 like this.
  7. Aug 1, 2016 at 12:33 PM
    #1047
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I would assume so as well, figured I'd ask to see if anyone else came across this one. It appears to be rubber, not polyurethane like the IEDLS bearing. I caved and ordered a stock replacement which means I'll need to replace it again soon
    I'll be waiting :spy:
  8. Aug 1, 2016 at 12:34 PM
    #1048
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Also have three new U Joints with zerks if interested
  9. Aug 1, 2016 at 3:33 PM
    #1049
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    watch out for these though, alot of the stock replacement CBs for the ranger that are the same as the IELDS ones are NOT SEALED, hence why they come with slingers. Thing is, those slingers will NOT fit onto our driveshaft properly, NOR will the stock slingers properly cover the ranger CB.
    You want a sealed bearing ranger CB if you are going to do this, IEDLS is one of them, i am sure there are more out there.
    I am still trying to get my driveline angles right for my install, just have not had time to figure it out.
    @HolyHandGrenade how did the one piece help with vibes?
  10. Aug 1, 2016 at 5:09 PM
    #1050
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It's much better. I did notice this weekend on the way to the Take Over that I get vibes at around 80 MPH. But, I don't need to be going that fast anyway...
  11. Aug 1, 2016 at 10:40 PM
    #1051
    nd4spdbh
    SoCal
    yeah its a constant battle.
    The biggest thing i am dealing with now is axle wrap which is quite bad with my single leaf AAL. Loaded down the overload acts like a traction bar and limits axle wrap, but unloaded the axle can swing alot more making it problematic.
    I just put some 2deg shims in to tilt the pinion up tonight, and it didnt help, BUT i am going to raise the CB quite a bit to see if i can get angles better.
    So far the best was the ranger CB mounted like it would be in the ranger (so lowest position), problem with this was i got some higher speed vibes now due to the pretty extreme angle out of the tcase.
    almost tempted to say eff it and get some dakars or all pro springs.
  12. Aug 3, 2016 at 12:47 PM
    #1052
    MTopp
    05 SR5 4x4
    Trying to solve vibes when you are getting axle wrap is almost impossible because your u joint angles will be constantly changing. I have multiple aals right now, but one is stiffer, so less axle wrap.
    What I ended up doing was what was best in my mind. After measuring all my angles a few times to confirm, I added a 2.5° steel shim to angle the rear axle flange down. This made the transmission flange and rear flange very close to parallel. I then dropped the carrier bearing to make the driveshaft almost a straight line, trans to rear axle. This makes the first and las u joint cancel eachother out vibe wise. The middle u joint has very minimal angle, meaning it won't cause large vibes.
    Theres other ways to do this, but this made the working angle on the u joints much less than any other method.
    I have barely any vibes now except at 30 ish and 60ish, which I think I need to drop the shaft another 1/8" or so
    Crom likes this.
  13. Aug 14, 2016 at 2:06 PM
    #1053
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Anyone interested in my bearing and 3 U Joints as I am not going to use them?
  14. Aug 14, 2016 at 2:54 PM
    #1054
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Just want what I paid for it shipped 73.00
  15. Aug 14, 2016 at 2:59 PM
    #1055
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Also have 3 new in the box U Joints for 20.00 each. Want to sell it as a set.
  16. Aug 14, 2016 at 4:42 PM
    #1056
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    ALL PARTS ARE SOLD
  17. Aug 14, 2016 at 4:43 PM
    #1057
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    ALL PIECES ARE SOLD
    MTopp likes this.
  18. Aug 23, 2016 at 3:49 PM
    #1058
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    For those of you who have done the install, have you experienced any fine vibrations or buzzing from the driveshaft? I figure if you install a more dense material in a system with some small vibration, that it would resonate into the frame of the truck.
  19. Aug 23, 2016 at 4:57 PM
    #1059
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    None but then again, my u-joint was toast...
  20. Aug 24, 2016 at 12:18 PM
    #1060
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
