Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Sep 3, 2016 at 1:40 PM
    #1081
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was planning on installing mine with the new plate UP
  2. Sep 3, 2016 at 1:53 PM
    #1082
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That was the only option for me. I know there're variations in the crossmembers depending on your trucks configuration.
    That said, I've since switched to a one once driveshaft. My vibes were worse with the Ford bearing. I was tired of cooking with it and worrying about angles and such.
  3. Sep 3, 2016 at 1:55 PM
    #1083
    DrFunker
    DrFunker Well-Known Member
    Thanks HHG. :thumbsup:
    How's the one piece working out?
  4. Sep 3, 2016 at 1:59 PM
    #1084
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It's better. No vibes until 75-85. They warned me that this might happen with it being so long and heavy. I don't need to go that fast anyway... The 35's seem to have pushed the vibes up a couple miles an hour though. Let's call it 77-87 now :D
    Before I have vibes all the time and bad at take off.
    DrFunker[QUOTED] likes this.
  5. Sep 3, 2016 at 3:27 PM
    #1085
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    A lighter, aluminum, driveshaft would cure the vibes completely I'm sure.
    BUT, I'm putting a twin stick FJ case in my truck. Eventually, a crawl box as well.
    When I do the crawl box, I'll need custom front and rear shafts.
    I was thinking of running an aluminum shaft day to day, and throwing the steel one in for off road. But, that's another $700 down the drain only to be tossed aside when I do the crawl box.
  6. Sep 7, 2016 at 6:23 AM
    #1086
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    That would be ideal if money weren't an issue
  7. Sep 8, 2016 at 2:43 PM
    #1087
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    CB came in!
    Anybody know the specs for the top plate that needs to be made off the top their head?
    Thickness, length, and width. Gonna try to knock it out at work real quick.
  8. Sep 8, 2016 at 2:46 PM
    #1088
    DrFunker
    I used 1 1/2" x 1/8" flat bar steel, ~7" long.
    The 2 holes on the CB bracket are 9/16" (kinda oval), but I went smaller. Enough to allow for the OME CB drop bolts.
    Let me say that I do not have this installed yet. It's on the to do list. I made the top bracket to be ready for the install.
  9. Sep 8, 2016 at 3:06 PM
    #1089
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Cool thanks. Realized after posting all I need is the same footprint as the CB :facepalm:
    Will I need longer bolts or will the factory ones be long enough. Im assuming they will be fine. The install is another story. Not sure when ill get to it, or what all it entails to be honest. Lol
    DrFunker likes this.
  10. Sep 8, 2016 at 3:12 PM
    #1090
    DrFunker
    If it is just the top plate and CB bracket, the factory bolts will be fine. That said, I have seen some pretty intricate fabrications in this thread to mount this CB up. :D
  11. Sep 8, 2016 at 3:43 PM
    #1091
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yep. Just the top plate and factory bolts. Nothing fancy, just replacing my worn out CB.
    Cut and cleaned up some stock..
    All ready to go
  12. Sep 8, 2016 at 3:46 PM
    #1092
    DrFunker
    sytfu510 likes this.
  13. Sep 8, 2016 at 3:53 PM
    #1093
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    So 1.5" bar stock is that right?
  14. Sep 8, 2016 at 3:59 PM
    #1094
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :thumbsup: super easy.
    1-3/8" x 7" x ~1/8"
    I just had some scrap 2" square tubing at work. cut it from that on the band saw and cleaned it up. then a couple 1/2" holes
  15. Sep 8, 2016 at 4:05 PM
    #1095
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks. I picked up some 1" square tubing and 1" flat bar without measuring. :facepalm:
  16. Sep 8, 2016 at 4:11 PM
    #1096
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    damn! lol
  17. Sep 9, 2016 at 9:24 AM
    #1097
    Michgnxj24
    Michgnxj24 Well-Known Member
    Virginia Beach
    2010 DCSB
    Jeraco Cap, Viair OBA
    Is this still open? I tried to find the part number on the website but it wasn't coming up.
  18. Sep 9, 2016 at 10:10 AM
    #1098
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Any chance EIDLS could make bearing assembly specifically for our trucks? Seems to be a demand for it.
  19. Sep 9, 2016 at 3:11 PM
    #1099
    Crom
    Nick
    San Diego, CA
    Millions
    I would think so. Adapting the ford one is kind of a pain.
    If you want, call them. Jeff is a good person to talk to.
    MTopp, DrFunker and samiam[QUOTED] like this.
  20. Sep 9, 2016 at 3:55 PM
    #1100
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    is it more than just adding the Top Plate? :confused:
