Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Nov 17, 2016 at 8:26 PM
    #1221
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    In for another round!
    ChadsPride likes this.
  2. Nov 17, 2016 at 8:29 PM
    #1222
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Hit up their website bud! You should be able to buy it from them direct now at the lower price.
  3. Nov 17, 2016 at 8:30 PM
    #1223
    Nimble9
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Will do tomorrow. I don't want to accidently buy too many being this tired haha
  4. Nov 17, 2016 at 9:20 PM
    #1224
    HenrikBP
    HenrikBP Well-Known Member
    Henrik
    SF, New Mexico
    2010 DCSB TRD Off-road
    It is my plan to rebuild the entire drive shaft. Just trying to avoid too much work - and cost - at the moment :)
  5. Nov 18, 2016 at 3:20 AM
    #1225
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Nov 18, 2016 at 12:19 PM
    #1226
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
  7. Nov 21, 2016 at 12:10 PM
    #1227
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
  8. Nov 22, 2016 at 5:33 PM
    #1228
    ST21_Taco
    ST21_Taco Well-Known Member
    Phill
    Northern VA
    2008 Tacoma DCSB
    Not enough
    Anyone want mine? $73 shipped. Ended up getting a better deal on a different part locally with install. Just shoot me a PM
    ////SOLD////
    Nimble9, JDMREXX and ChadsPride like this.
  9. Nov 23, 2016 at 2:41 AM
    #1229
    DrFunker
    DrFunker Well-Known Member
    A different part? :rolleyes:
    Do tell. :popcorn:
  10. Nov 23, 2016 at 6:55 AM
    #1230
    ST21_Taco
    Phill
    Northern VA
    2008 Tacoma DCSB
    Not enough
    I was talking to a friend of mine who works in parts at a Mercedes dealer I used to work at and he got me a non-poly bearing from one of his parts warehouses that won't require having to rig up the supports and I'm having one of my old techs install the part. All he want's is a bottle of cheap whiskey so couldn't turn that down.
  11. Nov 23, 2016 at 10:25 AM
    #1231
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You're obligated to tell us about this after you're done! :D
    DrFunker and ChadsPride like this.
  12. Nov 23, 2016 at 10:29 AM
    #1232
    ChadsPride
    :amen:
  13. Nov 23, 2016 at 11:25 AM
    #1233
    ST21_Taco
    Phill
    Northern VA
    2008 Tacoma DCSB
    Not enough
    Definitely will do. Hopefully will have it on by end of next week.
  14. Nov 28, 2016 at 8:09 AM
    #1234
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    DrFunker[QUOTED] and ChadsPride like this.
  15. Nov 28, 2016 at 8:35 AM
    #1235
    DrFunker
    12TRDTacoma[OP] and ChadsPride like this.
  16. Nov 28, 2016 at 8:42 AM
    #1236
    jesseunvoas
    Jesse
    08 TRD SPORT
    rubber vs poly is the only difference, I wanted to try this and if it fixes my vib issue then if this thing down the road goes to crap I can always buy the 125 usd one.
    MTopp, DrFunker and ChadsPride like this.
  17. Dec 1, 2016 at 10:27 PM
    #1237
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    I had this same issue (when I put it in drive or reverse there would be a thunk or clack) and I took it to a shop and the guy noticed there was a Crack in my u joint. my first thought was the center bearing which brought me to this thread a while back. another issue that the cracked u joint brought was when I'd let off the gas and then get back on it there would be a thunk or knock. the reason I'm saying all this is because you might want to check your joints. while the poly bearing may have remedied your symptoms I'd still go take a look
  18. Dec 2, 2016 at 5:56 AM
    #1238
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks for the info. I will double check, but my guy checked everything while he was under there putting in the new CB and doing my torque converter.
  19. Dec 2, 2016 at 7:37 PM
    #1239
    99TacoDriver
    South Louisiana
    Ahh you probably good then
  20. Dec 10, 2016 at 5:48 PM
    #1240
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Any updates? I've got the same setup as you and would like some insight before i dive in. I have the carrier bearing, in plastic, awaiting install....lookin all lonely like while i try to find as much info as i can. I'm most likely grabbing all the u joints before i do anything and replace while I'm at it. I'm just trying to eliminate some of the guess work in the length of the spacer needed.
