Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Dec 12, 2016 at 8:29 AM
    #1241
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    In theory would this fix the vibration I get at 20mph accelerating and decelerating?
    ChadsPride likes this.
  2. Dec 12, 2016 at 9:33 AM
    #1242
    DrFunker
    DrFunker Well-Known Member
    It may or may not. Sorry.....not a great answer. But if the problem is your CB, then it probably would fix it.
  3. Dec 12, 2016 at 9:40 AM
    #1243
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Torque converter? Did you get an aftermarket stall converter?
    Highly likely it would if your u joints are known good.
  4. Dec 12, 2016 at 9:41 AM
    #1244
    DrFunker
    Angles could be off too though. :anonymous:
  5. Dec 12, 2016 at 11:23 AM
    #1245
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I mean that is true if he has made any sort of weird mods. If the angles were off though he would experience it at other speeds and not just 20 mph.
    DrFunker[QUOTED] and ChadsPride like this.
  6. Dec 12, 2016 at 11:27 AM
    #1246
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Only mod that I have is the Wheelers progressive AAL, minus the factory Overload. So it should be close to what it is factory.
  7. Dec 12, 2016 at 11:27 AM
    #1247
    DrFunker
    Yeah.
  8. Dec 12, 2016 at 11:38 AM
    #1248
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Carrier bearing, given that your u joints are in good shape.
  9. Dec 12, 2016 at 11:50 AM
    #1249
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I got mine installed, and it went well for the most part. Threw the retaining nut in the milling machine and knocked the shoulder off of it since I didn't want that much of it hanging in limbo. I then put red Loctite on it upon reassembly.
    Couple Observations for those doing this in the future:
    - If the yoke doesn't seem like it wants to come off, keep trying. I had to work with it for about 3 hours, afraid that I was gonna crack it. I tried heat, penetrating oil, etc. and all it needed was just a bit more force. Wound up getting it off with the impact wrench and a 2/3 jaw gear puller from Oreilly's.
    - I didn't put either of the dust shields back on, hopefully that won't bite me in the rear at the price of bearing longevity.
    - I used the original u-joint that was there, but wound up messing up one of the nylon washers that sit in the bottom of the bearing cap by mashing the needle bearings into the material when they fell down in the cap unexpectedly. IF THE U-JOINT DOESN'T GO TOGETHER RELATIVELY EASY, PULL IT APART AND DOUBLE CHECK THE NEEDLES POSITION. I'll be replacing all 3 u-joints shortly since one of the seals is cracked on the forward-most joint and I messed up that washer in the middle joint.
    - Upon reassembly, I had vibrations at nearly every speed. I pulled the middle overload out of my dakars, as well as the 3 degree shims and things are MUCH better. I'm gonna sit down and right up a MatLab program to try to determine what height the bearing needs to be at for angular acceleration cancellation.
    - I installed my bearing opposite of OP. When you look at how the bearing is designed, the most material is along the flat side, which is where the constant weight of the DS would be located in the Ford application. I wanted to keep it that way when I installed it.
    - Just a word of wisdom. Mystik High Temp #2 grease is what Spicer has tested and approved for u-joints. It's cheap and available at Oreilly's. Looking at the specs it has great sling-out resistance and a high load rating. That said, clean grease is more important than type of grease, so ymmv.
    I still have a vibration at 18 mph and a minor high-speed vibration. I'll replace the u-joints before I mess with the height of the bearing.
    AR15xAR10, Thyces and ChadsPride like this.
  10. Dec 12, 2016 at 12:31 PM
    #1250
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    Is it normal to have to replace the carrier bearing at 30k miles?
  11. Dec 12, 2016 at 12:59 PM
    #1251
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The OE one? Yes. It's garbage.
    AR15xAR10 and ChadsPride like this.
  12. Dec 12, 2016 at 2:38 PM
    #1252
    MilesToEmpty
    Charles
    Frederick Co, MD
    '13 Baja TX
    This a direct fit for DCSB? I know napa is fussing it wont fit lol.
    I cant figure how to order the iedls one... link doesnt seem to work.
  13. Dec 12, 2016 at 4:43 PM
    #1253
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No, just a reman'd. Had some noises I didnt like and I think it was the Torrington bearing in the TC going out. New one solved that.
    AR15xAR10, scottalot and ChadsPride like this.
  14. Dec 12, 2016 at 4:51 PM
    #1254
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I called and asked about the group buy pricing / discount code. The guy said they aren't doing it anymore and that if we want to do a group buy order it'll be a minimum of 40 people. Dang
    ChadsPride and 12TRDTacoma[OP] like this.
  15. Dec 12, 2016 at 5:13 PM
    #1255
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good to know. I'll update the title again. I like how they just do it without announcing it or letting me know at least.
    MTopp and ChadsPride like this.
  16. Dec 14, 2016 at 7:17 AM
    #1256
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    I know the double cab long box will work can't answer if it will fit your truck
  17. Jan 6, 2017 at 5:48 PM
    #1257
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Well I finally got around to taking the driveshaft out again to replace my other 2 u joints and rotate the front section of the rear driveshaft 180* to make the driveshaft back to how it was supposed to be/balanced.
    Now have way less vibes using some I think 2.75 or 3" spacers in order to make the shaft pretty close to a stright line. Not perfect or ideal, but it's good enough for now. Happy until I can get a one piece or some other option.
  18. Feb 5, 2017 at 8:28 PM
    #1258
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    Will this group buy open again?
  19. Feb 26, 2017 at 11:50 AM
    #1259
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    x2^ Would love to get one of these for my DCSB '16 TRD sport if possible.
  20. Mar 6, 2017 at 8:50 PM
    #1260
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    How much is this regular price?
