Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Mar 6, 2017 at 8:59 PM
    #1261
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Going to state..... (dont know if you are 4x4 or not but this is to everyone)
    THIS IF FOR A 4X4 ONLY..... YOU NEED TO HAVE A SLIP JOINT AFTER THE CB for this to work.
    Also, been running my IELDS cb for awhile and things are good. Still have vibes but that is 100% due to shitty stock leafs and a single AAL that has axle wrap harder than 2 pac.
    MTopp likes this.
  2. Mar 6, 2017 at 9:00 PM
    #1262
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    F that. Good bye
  3. Mar 6, 2017 at 9:02 PM
    #1263
    nd4spdbh
    SoCal
    @12TRDTacoma
    Can you put a huge bolded note in the OP at the very top.... 4x4 only!?!?!
    12TRDTacoma[OP] likes this.
  4. Mar 6, 2017 at 9:04 PM
    #1264
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    F a prerunner.
  5. Mar 6, 2017 at 9:11 PM
    #1265
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Nah
  6. Mar 7, 2017 at 11:32 AM
    #1266
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Wrong guy haha I'm definitely a 4X4, but could I still get one of these for use on my third gen?? Would be interested in getting one if so
  7. Mar 7, 2017 at 12:07 PM
    #1267
    Jorgy1
    Jorgy1 Well-Known Member
    2019 MGM Tundra CrewMax 4x4
    I know 3 of us that would be in for a group buy
  8. Mar 7, 2017 at 6:21 PM
    #1268
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The group buy for now is on hold until further notice guys. Sorry to say.
  9. Mar 7, 2017 at 8:59 PM
    #1269
    nd4spdbh
    SoCal
    3rd gens have a different stock CB part number.... one would have to measure the shaft and verify it would fit.
    MTopp likes this.
  10. Mar 9, 2017 at 9:58 PM
    #1270
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  11. Mar 9, 2017 at 10:13 PM
    #1271
    AR15xAR10
    Is no one worried about hanging this thing up on a rock? I mean, it doesn't move the center of the drive shaft down by much but still....clearance is clearance...
    MTopp likes this.
  12. Mar 9, 2017 at 11:16 PM
    #1272
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You'd be more inclined to hang up the gas tank up on a rock before catching this thing on a rock bud.
  13. Mar 10, 2017 at 6:08 AM
    #1273
    AR15xAR10
    Also, it would be totally fine on my barely lifted truck?
    I've got a noise that i believe is either the cheap carrier bearing i just installed or one of my new ujoints. Some people told me to try this one. But i don't want to mess up my pinion angle...
    MTopp likes this.
  14. Mar 10, 2017 at 6:14 AM
    #1274
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It still isnt the lowest hanging part on my truck, I check every time I hear some scraping when wheeling, to see if I got it.. It never does. The frame, sliders, crossmembers, always touch first
    MTopp likes this.
  15. Mar 10, 2017 at 6:21 AM
    #1275
    AR15xAR10
    I just worry because a replacement driveshaft is like $800
    No biggy then. Surely the angle won't be changed that much...i'll look at it today... i don't want the cb to be the low spot because my truck isn't as lifted as everyone else that did this mod
    MTopp likes this.
  16. Mar 10, 2017 at 6:24 AM
    #1276
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That won't change the relation of cb to frame. It will still sit in the same spot as mine or anyone elses. :thumbsup:
  17. Mar 10, 2017 at 6:30 AM
    #1277
    AR15xAR10
    But lower is what i mean...
    The drive shaft wouldn't be tucked up in the crossmember like it is now....it'd be an little bit lower at that point with this Poly CB, right?
    I'm sure i'm overthinking this. I'm still stressed out about the whole thing
  18. Mar 10, 2017 at 6:44 AM
    #1278
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You are right about that, it will move the entire assembly down, but only by a couple inches at most. Lift height won't affect anything tho, besides angles, and you'll be good there too I'd imagine
    No worries man. I can relate.. I dive deep into everything.. Need to know all the info first. I can appreciate that. ;)
  19. Mar 11, 2017 at 3:00 AM
    #1279
    stevotivo12
    Stephen
    an upgraded driveshaft isnt that much homie. I had a quote ran up for a custom one piece steel driveshaft at one point when I thought Id never get rid of vibes ( but i did, and you can too!) and even that came out to less. You could spend over $800 for a carbon fiber driveshaft if you wanted to go that way... plus side is that would DEFINITELY not transmit any driveline vibrations
    MTopp and AR15xAR10[QUOTED] like this.
  20. Mar 15, 2017 at 8:46 PM
    #1280
    AR15xAR10
    I noticed one side of this thing is different from the other....not sure if its directional or what
    MTopp likes this.
