Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Mar 16, 2017 at 8:22 PM
    #1301
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    It actually does since your pinion is actually significantly lower than the frame than mine is
  2. Mar 16, 2017 at 8:23 PM
    #1302
    AR15xAR10
    Guess i'll just have to send it and lift this pig
  3. Apr 25, 2017 at 9:33 AM
    #1303
    Beejis60
    Beejis60 Member
    Any chance another GB is on soon or someone is selling their CSB?
  4. Jul 9, 2017 at 12:52 AM
    #1304
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    DCSB Owners:
    Does the flipped orientation of the IDELS bearing rob you of any ground clearance? Or does it virtually hang as low as the stock CB? It's hard to tell. I read through this thread a week or two ago but didn't see much talk on it. And thanks for taking the plunge @MonkeyProof.
    Is everyone else still pleased with their poly CB? Rebuilding both drive shafts soon and need to confirm whether it's worth the $160CAD for a long-term solution before ordering. Thanks!
    Midnighttaco08 likes this.
  5. Jul 10, 2017 at 12:33 PM
    #1305
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    it dropped it a tad.. not much more than stock. nothing noticeable at all. It hasnt been a problem at all since install, and it has been prefect ever since install.
    do it..
    G.T. likes this.
  6. Jul 10, 2017 at 1:29 PM
    #1306
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  7. Jul 10, 2017 at 1:31 PM
    #1307
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    looks the same honestly. might just be black Poly... same mold design and everything. either that, or they used rubber but the same mold as the Poly IEDLS one.
  8. Jul 10, 2017 at 1:32 PM
    #1308
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    how did I miss this!? :pout:
  9. Jul 10, 2017 at 1:36 PM
    #1309
    MadTaco461
    CA
    Kinda stock
    I can't tell the difference either besides the Spicer one is $100 cheaper. All our driveline parts are Spicer OEM so it's not a cheap knock off. Just wanted to share in case someone is looking to do some testing.
    Pirhett likes this.
  10. Jul 10, 2017 at 1:37 PM
    #1310
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I would try it if I didnt already have the IEDLS one. it really does look the same! nice find man. people should get on this for sure!
    MadTaco461[QUOTED] likes this.
  11. Jul 10, 2017 at 1:40 PM
    #1311
    MadTaco461
    CA
    Kinda stock
    My buddy is having center bearing issues so I'll try to convince him to test this one out for me. I'll look at it side by side with my IEDLS that I have.
    XPOTRPR[QUOTED] likes this.
  12. Jul 10, 2017 at 1:46 PM
    #1312
    Pirhett
    Rhett
    San Diego
    Stock...
    how do these compare to OEM?
  13. Jul 10, 2017 at 1:53 PM
    #1313
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. way better. its Poly vs rubber.
    MadTaco461 and Pirhett[QUOTED] like this.
  14. Jul 10, 2017 at 1:59 PM
    #1314
    Pirhett
    Rhett
    San Diego
    Stock...
    ah lol
  15. Jul 10, 2017 at 2:12 PM
    #1315
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    do it @Pirhett
    if its the same, you wont be disappointed. if anything, it helps others by knowing if its the same or not.
    Pirhett likes this.
  16. Jul 10, 2017 at 3:26 PM
    #1316
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    so long as the bearing is a SEALED bearing you should be good, as you wont be able to use that slinger on our driveshafts to keep shit out of a non sealed CB.
  17. Jul 10, 2017 at 4:49 PM
    #1317
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    I may give that Spicer XC (sealed bearing) a whirl. I'm in a pinch to get a bunch of maintenance done before some upcoming wheeling trips so I opted to take the truck in to a driveshaft shop down the street. They're strictly Spicer. I'll put in a request for this exact bearing and report my findings.
    I wouldn't be able to get the IDELS one shipped to Canada and installed in time unfortunately. So much to do, so little time!:goingcrazy:
    XPOTRPR likes this.
  18. Jul 10, 2017 at 5:07 PM
    #1318
    nd4spdbh
    SoCal
    if its sealed you should be good. an OEM rubber CB for the ford bearing is going to be MUCH better than the OEM toyota bearing, as the OEM toyota bearing had to allow the driveshaft to move forward n back an inch or so through it for the prerunners (as they dont have a slip joint after the center u joint), and any ford setup with a CB always had a slip joint after the center u joint so the ford CB has always been designed to be much more stiff.
  19. Jul 10, 2017 at 5:17 PM
    #1319
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    So what if the shop recommends a sealed Spicer XC center bearing specific to the Tacoma? Should I opt for the Ford Ranger version?
  20. Jul 10, 2017 at 5:18 PM
    #1320
    nd4spdbh
    SoCal
    A "spicer XC" cb that is meant for the truck is likely the exact same one as the truck came with (as spicer makes our driveline components). If you went with a ford ranger one, its NOT going to be just a bolt up. You will need at the very least a plate to capture the CB, and likely some fine tuning with spacers to get the angles right.
