Closed (for now): Group Buy: IEDLS Polyurethane Carrier Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 11, 2016.
  1. Mar 14, 2016 at 7:20 AM
    #121
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So where does the pressing of the bearing come from as mentioned in other posts?
  2. Mar 14, 2016 at 7:22 AM
    #122
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I BELIEVE the bearing needs ti be pressed in. As it shouldn't just be floating around in the shaft as easily to just install it.
    Of course, I didn't do that part so don't take my word as gospel.
  3. Mar 14, 2016 at 7:25 AM
    #123
    12TRDTacoma
    Rob
    Concordia
    Boosted
  4. Mar 14, 2016 at 7:30 AM
    #124
    UPR TAC
    UPR TAC Member
    Please add me to the list.
  5. Mar 14, 2016 at 7:35 AM
    #125
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Got it!
  6. Mar 14, 2016 at 7:46 AM
    #126
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Ahhhhhhhhhhhhhhhhhh so I guess I will have to pay to have it done okay thanks.
  7. Mar 14, 2016 at 9:16 AM
    #127
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Subbed. I just replaced mine literally last week. Depending on final price it might be worth it to get One and just hang on to it till I need it
  8. Mar 14, 2016 at 9:22 AM
    #128
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    And just to clarify the only special tools needed to do this job are a 2 jaw puller and a torque wrench. You have to take the ujoint apart which can me done with two sockets and a vice (or two peices of pipe. One to fit inside to push the joint out and on larger to accept the ujoint). Then remove the nut and use the puller to remove the yoke and old bearing. Then put the new bearing on and the yoke. Torque to 153ft/lbs to set the bearing then back off and set the final torque to 55 ft/lbs. then use the vice and sockets to reassemble the ujoint. It's a very easy process
    Hartford and 12TRDTacoma[OP] like this.
  9. Mar 14, 2016 at 9:23 AM
    #129
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So for someone like me that is zero handy what would something like this cost to do???
  10. Mar 14, 2016 at 9:37 AM
    #130
    DormaTaco
    DormaTaco Well-Known Member
    Shawn
    MN
    '15 TRD Sport DCLB 4X4
    And now we wait...
  11. Mar 14, 2016 at 10:06 AM
    #131
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here is the update. I was just emailed back by a man named Jeff from IEDLS. This is what he had to say about it:
    Robert,
    Yes we can give a discount for Quantity purchasing if you were to buy more
    then 20 at a time we can sell them for $73.00 each. Please allow two to
    three weeks.
    Thank You
    Jeff Gilroy
    Inland Empire Drive Line Service Inc..
    909-390-3030
    nfs257 and Drainbung like this.
  12. Mar 14, 2016 at 10:08 AM
    #132
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    73.00 from 125.00 now that's a discount.
  13. Mar 14, 2016 at 10:09 AM
    #133
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    This is the link I was just about to post as the above steps are how I am going to replace mine AND I will also be using a plate on top so as it doesn't vibrate up/out.
    Also, this is the email I received last week from IEDLS referencing part number 211590-1XS:
    Benjamin,
    This bearing has the same bearing I.D. as the Toyota but the way it bolts in is different. It my work you my have to modify the way it bolt in.
    Thank You
    Jeff Gilroy
    Inland Empire Drive Line Service Inc..​
  14. Mar 14, 2016 at 10:11 AM
    #134
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    @12TRDTacoma @Unchained 5150
    The hardest parts for me when I changed my CB out was that I had 2 u-joints actually bent and the 20 ton hydraulic press was struggling. Otherwise a 4x4 and a socket and hammer and you can replace the U-joints on your own. The bearing literally just pulled off by hand and the new one slipped right on.
    12TRDTacoma[OP] likes this.
  15. Mar 14, 2016 at 10:12 AM
    #135
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    Awesome price
  16. Mar 14, 2016 at 10:12 AM
    #136
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    How did you bolt the carrier bearing up? Got any pics of the install???
  17. Mar 14, 2016 at 10:18 AM
    #137
    nfs257
    DFW
    She gone
    I may be in for 2.
  18. Mar 14, 2016 at 10:20 AM
    #138
    nfs257
    DFW
    She gone
    Originally I was just using the stock location. My angles were all messed up due to shitty fab work. I have the pillow block one. (Blue in the first pics)
    Then I had the actual mount reworked.
  19. Mar 14, 2016 at 10:23 AM
    #139
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Can you sign me up? And when is this happening?
  20. Mar 14, 2016 at 10:24 AM
    #140
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Will you install mine for me???? :D
    nfs257 likes this.
