CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 2, 2019 at 8:07 PM
    #241
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I honestly do not know. Tor is the only one that I know with cams. Hopefully he can chime in here.
  2. Jul 2, 2019 at 8:19 PM
    #242
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im ready to pay and start this off, unless maybe another cam specification is desired.....
    I wouldn’t mind a pretty rumpity mean idle
    BC stoker kit next or sleeves my friends?..
    Roostfactor and ThomasMore66 like this.
  3. Jul 2, 2019 at 8:21 PM
    #243
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Oh c'mon man. Give me a few weeks to recover. Sleeves would look great though. And I'm not talking ink work.
  4. Jul 2, 2019 at 8:23 PM
    #244
    GT7
    Grant
    Phoenix
    2013 DCLB
    Seriously man? It would go great with your earrings :devil:
  5. Jul 2, 2019 at 8:23 PM
    #245
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Howd you know?
  6. Jul 2, 2019 at 8:24 PM
    #246
    GT7
    Grant
    Phoenix
    2013 DCLB
    Your posts sometime recently about purple earrings
  7. Jul 2, 2019 at 8:24 PM
    #247
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Damn, next people will know my hair is 2' long too.
    BassAckwards and GT7 like this.
  8. Jul 2, 2019 at 8:25 PM
    #248
    ThomasMore66
    Dallas/Fort Worth & Durango
    Those are called gauges.
  9. Jul 2, 2019 at 8:28 PM
    #249
    ThomasMore66
    And once we get cams we don’t need the cam gears, right?
    White lightning boosted and GT7 like this.
  10. Jul 2, 2019 at 8:32 PM
    #250
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JustDSM shed some light on that.
  11. Jul 2, 2019 at 8:33 PM
    #251
    GT7
    Grant
    Phoenix
    2013 DCLB
    This is correct.
  12. Jul 2, 2019 at 8:35 PM
    #252
    ThomasMore66
    I’ve spent a bunch of money on these cam gears. I’ll add them to the 650 injectors I bought from URD. Somebody make me an offer.
  13. Jul 2, 2019 at 8:45 PM
    #253
    Jesse
    Poulsbo
    15' DCSB OR S/C
    2nd gen marketplace??
  14. Jul 3, 2019 at 3:33 AM
    #254
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t want a rumpity idle. Sorry to be a party pooper, guys.
    GT7[QUOTED] likes this.
  15. Jul 3, 2019 at 5:18 AM
    #255
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mine with very low overlap have some. Not like some American muscle cars by any means. Enough that if you listened carefully you'd know. You can kind of hear their sound in the video of me walking around my truck.
  16. Jul 3, 2019 at 5:43 AM
    #256
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    i want cams... but need to mod tundra too...
  17. Jul 3, 2019 at 6:24 AM
    #257
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I’m still in. I can wait for others that need extra time though.
  18. Jul 3, 2019 at 6:26 AM
    #258
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Same here.
  19. Jul 3, 2019 at 6:30 AM
    #259
    Wild Heart
    Daryn
    2015 DCLB BRM
    If we have 60 days, do we all have to order the same day or do we each have 60 days to put in an order?
  20. Jul 3, 2019 at 6:47 AM
    #260
    BillDaCat8
    Jake
    PHX
    We need five orders. Up front, to start.
    loginfailed likes this.
