CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 3, 2019 at 6:53 AM
    #261
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I’m going to take this as a “yes”
  2. Jul 3, 2019 at 7:00 AM
    #262
    BillDaCat8
    Jake
    PHX
  3. Jul 3, 2019 at 7:19 AM
    #263
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
  4. Jul 3, 2019 at 7:30 AM
    #264
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Another email or two, and I bet it will be better for me to be "In".
    loginfailed and GT7 like this.
  5. Jul 3, 2019 at 8:11 AM
    #265
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If I had an example to see how lopey the idle would be with these, I'd potentially be in.
    Murphinator likes this.
  6. Jul 3, 2019 at 8:16 AM
    #266
    GT7
    Grant
    Phoenix
    2013 DCLB
    I think we could potentially have more people if we had feed back. I wouldn’t mind paying for them, maybe he can expedite shipping, I can get them installed and make a few videos
  7. Jul 3, 2019 at 8:17 AM
    #267
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    ^^My hero
    Murphinator and GT7[QUOTED] like this.
  8. Jul 3, 2019 at 8:19 AM
    #268
    GT7
    Grant
    Phoenix
    2013 DCLB
    @BillDaCat8 maybe kiel would do this? Wonder what lead time is.
    loginfailed likes this.
  9. Jul 3, 2019 at 9:42 AM
    #269
    BillDaCat8
    Jake
    PHX
    These are custom grinds. They should be able to do it however you like. Mild to wild. Each set will have it's own spec card.
  10. Jul 3, 2019 at 10:00 AM
    #270
    BillDaCat8
    Jake
    PHX
    I'm sure he'd do that if that set was full price. He's made it very clear that five sets must be pre-paid to get the discount.
    Lead time I'm told is 2-3 weeks.
  11. Jul 3, 2019 at 10:08 AM
    #271
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I’ll be one of the first five. Just let me know when you’re ready.
  12. Jul 3, 2019 at 10:09 AM
    #272
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ok understood
  13. Jul 3, 2019 at 11:15 AM
    #273
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hadn't heard mine at the Coffee and Cars?
    loginfailed[QUOTED] likes this.
  14. Jul 3, 2019 at 11:17 AM
    #274
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sent an email. We'll see what is more advantageous for me. I hang in the balance until the next couple of days.
  15. Jul 3, 2019 at 11:22 AM
    #275
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have, but I want to maitain a stock-like idle smoothness. I don't know enough about camshaft profiles to know what specs to go for.
  16. Jul 3, 2019 at 11:29 AM
    #276
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    But yours have the vvti lockout right, so they are always full(or at least consistent) timing?
    If we’re keeping vvti, wouldn’t that smooth out the idle a bit even with a more aggressive profile? This is a question, I really don’t know.
  17. Jul 3, 2019 at 11:40 AM
    #277
    GT7
    Grant
    Phoenix
    2013 DCLB
    Probably
    I wish I knew more about cam profiles. Like what is more advantageous for 400 hp vs 600+ hp with a built motor.
    Supercharger being the constant, not turbo
  18. Jul 3, 2019 at 12:07 PM
    #278
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With an 840 RPM idle, you couldn't even tell that it had cams. Static or not. With a 740, you could just tell. I imagine that with the added function of VVT-I, you wouldn't tell.
  19. Jul 3, 2019 at 12:51 PM
    #279
    ThomasMore66
    Dallas/Fort Worth & Durango
    I want to do this, but I feel we need more data on hp potential, sound, rpm range (do I want to change the rpm range if I'm 4 wheeling up a hill in 4lo?).
    Roostfactor, DocME and Murphinator like this.
  20. Jul 3, 2019 at 1:27 PM
    #280
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    :spy:
    GT7 likes this.
