CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 3, 2019 at 2:08 PM
    #281
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You'll have more across the RPM range, with the s/c spec'd cams, than stock. Just think of it having more lift and more duration. More are in and out across the range. Makes more power more easily.
  2. Jul 3, 2019 at 2:09 PM
    #282
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    How hard is it to swap springs? I think that may be over my pay grade, but maybe not..
  3. Jul 3, 2019 at 2:10 PM
    #283
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Could a reasonable hp estimate be made by calculating a % of increase in duration?
  4. Jul 3, 2019 at 2:16 PM
    #284
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Same. But Ill figure it out regardless
  5. Jul 3, 2019 at 2:49 PM
    #285
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    After you pull the cams out, you'll have to thread in a compressed air hose into the sparkplug hole. Then you can remove the spring buckets and use a valve spring compressor to squeeze the springs while you coax the valve retainers out. once these are out, you can pull the spring off. Then while you're in there you'll probably want to replace the valve seals. You can then use the spring compressor to compress the new springs and lower over the valve stem, then secure with the retainers. Repeat, 23 more times.....Side note, if you can get a spring compressor with a rubberized handle you be glad you did. The oils from the engine make those little tools tough to grip and hard on the hands.
    Late '80's chevy engines were terrible about the valve seals. Tell tale blue smoke cloud at startup that clears up quickly. Had to do a couple sets in my youth.
  6. Jul 3, 2019 at 3:40 PM
    #286
    ThomasMore66
    Dallas/Fort Worth & Durango
    Why would you want another set of cams?
  7. Jul 3, 2019 at 4:37 PM
    #287
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Nice tips man! Thank you.
    DocME[QUOTED] likes this.
  8. Jul 3, 2019 at 4:46 PM
    #288
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I guess the dealer is the best place to get valve seals right?
  9. Jul 3, 2019 at 4:47 PM
    #289
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ill get mine from @BillDaCat8
  10. Jul 3, 2019 at 5:09 PM
    #290
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Surprised nobody suggested doing head porting as we're this deep.
  11. Jul 3, 2019 at 5:23 PM
    #291
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Shhh!
  12. Jul 3, 2019 at 5:25 PM
    #292
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Mine, mine mine mine
    GT7 likes this.
  13. Jul 3, 2019 at 5:40 PM
    #293
    ThomasMore66
    Yeah, I went there earlier.
  14. Jul 3, 2019 at 6:00 PM
    #294
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'd love to. Maybe in a year when I have a 2nd car to commute while this is on the rack.
  15. Jul 3, 2019 at 8:42 PM
    #295
    BillDaCat8
    Jake
    PHX
    Here’s a cool install tool: https://m.youtube.com/watch?v=eGHvQe5Ml8k the OTC tools are similar.
    I’m giving some thought to purchasing the factory tools for this sort of job and then whoring them out to those interested to help offset the cost.
    Obviously that’s another discussion and surely putting the cart before the horse. But, if it helps assuage the apprehensiveness of anyone that may be considering this...
    12TRDTacoma, Roostfactor and DocME like this.
  16. Jul 3, 2019 at 8:44 PM
    #296
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im in for that with ya
  17. Jul 3, 2019 at 8:49 PM
    #297
    DocME
    California
    '07 FJ Cruiser
    That’s pretty damn sweet.
  18. Jul 3, 2019 at 8:54 PM
    #298
    BillDaCat8
    Jake
    PHX
    I’m sure that some porting would help some. But, with the need to pull the heads and timing cover to get that sort of thing done, we’re well beyond “bolt-ons”
  19. Jul 3, 2019 at 8:58 PM
    #299
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That should be the new thread title. (Well beyond bolt ons 1grfe)
  20. Jul 3, 2019 at 9:01 PM
    #300
    ThomasMore66
    We already established we were far from shore.
