CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 7, 2019 at 10:18 PM
    #341
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    I love California...unless we’re talking car parts. The happiness of saving money doesn’t out weigh the sadness of losing hp
  2. Jul 8, 2019 at 6:46 AM
    #342
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  3. Jul 8, 2019 at 6:54 AM
    #343
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's great news!
  4. Jul 8, 2019 at 11:16 AM
    #344
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'll send an email this evening!
  5. Jul 8, 2019 at 2:22 PM
    #345
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
  6. Jul 8, 2019 at 3:49 PM
    #346
    ThomasMore66
    Dallas/Fort Worth & Durango
  7. Jul 8, 2019 at 4:45 PM
    #347
    Jesse
    Poulsbo
    15' DCSB OR S/C
  8. Jul 8, 2019 at 6:26 PM
    #348
    Wild Heart
    Daryn
    2015 DCLB BRM
    Email sent.
  9. Jul 8, 2019 at 6:30 PM
    #349
    Jesse
    Poulsbo
    15' DCSB OR S/C
    GT7 likes this.
  10. Jul 8, 2019 at 7:10 PM
    #350
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Jul 8, 2019 at 8:14 PM
    #351
    BillDaCat8
    Jake
    PHX
    Thanks guys. I'm happy to help.
    Kiel got back to me.
  12. Jul 8, 2019 at 8:15 PM
    #352
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ummm eff yeah!
    GT7 likes this.
  13. Jul 8, 2019 at 8:16 PM
    #353
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Nice, been watching my email like a hawk
  14. Jul 8, 2019 at 8:23 PM
    #354
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct me if I am wrong, but I was under the assumption that TRD injectors with the TRD tune running 2.7 pulley with AFE CAI and 255lph pump had the injectors operating at over 90% duty cycle. Likely not enough headroom for another major mod like cams. Meaning larger injectors should be used. What I am less clear on is if the O2s will calibrate the ECU for the larger injectors, or if that will then also require the tune. Thus then safely adding cams in my case also has the pile on affect of adding larger injectors plus tune.
    Really I should get an injector duty cycle reading, my first attempt at that did not work.
  15. Jul 8, 2019 at 8:28 PM
    #355
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JustDSM can you provide clarity on this question?
    crashnburn80[QUOTED] likes this.
  16. Jul 8, 2019 at 8:31 PM
    #356
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I think you will still be in the comfort zone. My ipw #s have always been just fine. Cams are custom to spec orders. Mild is totally possible.
  17. Jul 8, 2019 at 8:32 PM
    #357
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    With a 2.5” pulley and TRD injectors the duty cycle at WOT in my truck was 95%. Switching to 640cc injectors, duty cycle is around 65%.
    Roostfactor, tacotuesday81 and Torspd like this.
  18. Jul 8, 2019 at 8:34 PM
    #358
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I went from a 10% duty cycle at 60mph to 6% with 650s.
  19. Jul 8, 2019 at 8:34 PM
    #359
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It has to be wild enough to justify the cost, but mild enough not to lose low end.
    Which tune are you running?
  20. Jul 8, 2019 at 8:36 PM
    #360
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Cams or tuning can be adjusted any way you like. If anything my truck is more mellow for street commuters use. Yet wilder when I want. Best of both worlds.
