CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 27, 2019 at 9:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Then they will be great performers!
    Mine didn't, and their custom specs were all mid and top end. With my transmission's gearing, low RPM acceleration is dreadfully slow. Past that, head is in head rest. ;)
  2. Jun 27, 2019 at 9:08 AM
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    This is a grind that Kelford has developed specificaly for the supercharged 1gr.
    I have not yet asked for the stock cam specs. (If he's got them readily available)
    Torspd[QUOTED] likes this.
  3. Jun 27, 2019 at 9:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You can ask for comparison reasons. Not really that necessary though. As they have been making them for years now. Just for the wrong market, since not our market. We catalog.
  4. Jun 27, 2019 at 9:12 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    So many questions!
    That posting from the previous attempt answered a lot of my questions.
    @BillDaCat8 are these our cams reground? Or are they new?
    Do we have choices on the valve spring rates or do they already know what we need?
    I’m a FIRM maybe.
  5. Jun 27, 2019 at 9:13 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    New, says in first post. this was my first question as well
    DocME[QUOTED] likes this.
  6. Jun 27, 2019 at 9:14 AM
    DocME
    California
    '07 FJ Cruiser
    Missed that little bit there
  7. Jun 27, 2019 at 9:15 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    I believe they already have what we need for the correct valve springs. Ill be getting what they recommend. group buy or not these are mine
    Roostfactor, Torspd and BassAckwards like this.
  8. Jun 27, 2019 at 9:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The exhaust are as easy to install as the cam gears, except with the addition of removing the cams. The intake are more challenging, without removing timing cover. I've been at this a long time, and have never done it myself. I have seen one successful member. I will be attempting that probably this weekend. I'll be able to report back what I find.
  9. Jun 27, 2019 at 9:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It's too bad that LCE doesn't work a deal to carry these. People would have been installing these years ago.
    Regardless, the wave is growing.
    I'd fork out for another "turbo" intake set that works with VVT-I. Or maybe I could send those in. Hmmm.
    Biscuits, bobsuruncle and Roostfactor like this.
  10. Jun 27, 2019 at 9:32 AM
    BillDaCat8
    Jake
    PHX
    Ours are the early 1GR's. The later motor is the roller rocker. It’s in the newer 4runners and FJ's. Dual VVTI, Cartridge oil filter, etc... Tacoma never got that motor.
  11. Jun 27, 2019 at 12:12 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    FinnJ, Biscuits, Mech_Eng and 7 others like this.
  12. Jun 27, 2019 at 12:29 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'd be in if we can wait til spring.
    Murphinator likes this.
  13. Jun 27, 2019 at 12:39 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    relevant?
    Camshafts
    The 1GR-FE engine had double overhead camshafts that were made of cast iron alloy. Both the primary and secondary timing chains used pitch roller chains with a pitch of 9.525 mm. The intake camshafts were driven by the crankshaft via the primary timing chain. The exhaust camshafts were driven by the intake camshaft of the respective bank via the secondary timing chain.
    The primary timing chain used one chain tensioner (ratchet type with a non-return mechanism), and each of the secondary timing chains for the right and left banks used one chain tensioner. Both the primary and secondary chain tensioners used a spring and oil pressure to maintain proper chain tension at all times. Furthermore, the timing chains were lubricated by oil jets.
    For the dual VVT-i 1GR-FE, the cam lobes had indented R profiles to increase valve lift when the valve began to open and as it finished closing.
    Shimless type valve lifters/rocker arms
    For valve actuation, the VVTi 1GR-FE had shimless type valve lifters. The dual VVTi 1GR-FE engine, however, had roller rocker arms with built-in needle bearings that reduced the friction that occurred between the camshafts and the roller rocker arms. The hydraulic lash adjuster – located at the fulcrum of the roller rocker arm – consisted primarily of a plunger, plunger spring, check ball and check ball spring. Through the use of oil pressure and spring force, the lash adjuster maintained a constant zero valve clearance.
    VVT-i
    For the 120-Series LandCruiser Prado and Mk.7 Hilux, the variable inlet valve timing (VVT-i) a 50 degree range of adjustment (relative to crankshaft. Furthermore, the 1GR-FE engine had valve overlap of -6 degrees, intake duration of 232 degrees and exhaust duration of 236 degrees.
    1GR-FE VVT-i: Valve Timing
    Intake Open -8° to 42° BTDC
    Close 60° to 10° ABDC
    Exhaust Open 54° BBDC
    Close 2° ATDC
    Oil passages on the intake and exhaust camshafts enabled the ECU to adjust camshaft advance and retard via:
    • An oil control valve (mounted on the cylinder head); and,
    • Vane-type actuators on the ends of the intake camshafts.
    Roostfactor and BillDaCat8[OP] like this.
  14. Jun 27, 2019 at 12:42 PM
    BillDaCat8
    Jake
    PHX
    My timing cover needs re-sealing anyway. So, it’s coming off regardless.
    I’ve been waiting to do that job until I have all this new shit to bolt on. (Injectors/rails etc...)
  15. Jun 27, 2019 at 1:14 PM
    #35
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm a pretty firm "in".
  16. Jun 27, 2019 at 1:19 PM
    #36
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I dont believe its going to tag anyone since you edited the post.. if you post the list as a new reply, it should tag everyone
  17. Jun 27, 2019 at 1:29 PM
    #37
    BillDaCat8
    Jake
    PHX
    drat!
    I'll try that.
    BassAckwards[QUOTED] likes this.
  18. Jun 27, 2019 at 1:30 PM
    #38
    BillDaCat8
    Jake
    PHX
  19. Jun 27, 2019 at 1:32 PM
    #39
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I’m also down if we can wait a bit. Too much good stuff going on right now :bananadead:
  20. Jun 27, 2019 at 1:36 PM
    #40
    BassAckwards
    Im also in if we can wait a little while.. Strapped for mod money, but i know this is a worthy one..
