CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 13, 2019 at 4:46 AM
    #541
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
  2. Jul 13, 2019 at 4:59 AM
    #542
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Dont sweat it man, I talked to him in Wednesday. It is very much still open to others
  3. Jul 13, 2019 at 5:09 AM
    #543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This I've got to see!
  4. Jul 13, 2019 at 9:39 AM
    #544
    ThomasMore66
    Dallas/Fort Worth & Durango
  5. Jul 13, 2019 at 2:19 PM
    #545
    ThomasMore66
    I may have found access to a dyno.
  6. Jul 13, 2019 at 4:09 PM
    #546
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Wow man! That is great news. What's the rate per run?
  7. Jul 13, 2019 at 4:59 PM
    #547
    ThomasMore66
    Got a deal through a friend. $75 for three pulls. Gonna try to do it this coming Friday.
  8. Jul 13, 2019 at 5:01 PM
    #548
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That is a killer deal.
  9. Jul 14, 2019 at 12:18 AM
    #549
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Man, I want these cams.
    But I don’t know where to get $2000. Rob an armoured truck? Gofundme? Attempt to beat the house at a casino?
  10. Jul 14, 2019 at 1:25 AM
    #550
    Athlaos
    Leigh
    Edmonton
    I sent an email to Kiel asking if July 27 is too late to send him the payment. I can probably get the money together on that day if I talk to my loan sharks again and don’t eat very much for a month.
  11. Jul 14, 2019 at 6:06 AM
    #551
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Excellent. Be a great to know where your truck is right now, and to see what the gains are with the cams.
    Allowed to name the shop?
  12. Jul 14, 2019 at 6:52 AM
    #552
    GT7
    Grant
    Phoenix
    2013 DCLB
    Start selling stuff you dont use anymore on kijiji
    Athlaos[QUOTED] likes this.
  13. Jul 14, 2019 at 7:56 AM
    #553
    Athlaos
    Leigh
    Edmonton
    Was just thinking that.
  14. Jul 14, 2019 at 8:13 AM
    #554
    ThomasMore66
    https://www.evodynamics.com/
    Roostfactor and Athlaos like this.
  15. Jul 14, 2019 at 11:55 AM
    #555
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Right there with ya!
    I simply cant forecast my near future financial situation so must stay jealous and watch from the sidelines.
    DocME and Athlaos[QUOTED] like this.
  16. Jul 14, 2019 at 11:56 AM
    #556
    Roostfactor
    TX panhandle
    What cam profiles are the sc guys going with?
    All the same?
  17. Jul 14, 2019 at 12:31 PM
    #557
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Black jack. Dyslexia gives an advantage
  18. Jul 14, 2019 at 12:33 PM
    #558
    Athlaos
    Leigh
    Edmonton
    Lol
  19. Jul 14, 2019 at 3:28 PM
    #559
    Athlaos
    Leigh
    Edmonton
    Sold a bass guitar amp. I’m 15% of the way to the cams.
  20. Jul 14, 2019 at 3:30 PM
    #560
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Donate some blood, plasma, maybe a kidney, you should get close.
