CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 22, 2019 at 11:13 AM
    #721
    tacotuesday81
    tacotuesday81 darkeye
    Darcy
    beaumont, alberta, Canada
    2014 Tacoma TRD offroad
    Urd tcai. Dtlt headers maf call. Urd stage 3+ cluch lws, magnusson 2.55 pully, uconn ems
    What are your dyno numbers at?
  2. Jul 22, 2019 at 12:01 PM
    #722
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Last dyno was 404wftlbs and 341whp. It's weird though, I've dynoed three times in the last year, my boost keeps going up but my numbers go down. First time was 435wftlbs and 351whp, reduced my belt slip and second time was 420wftlbs and 361whp, then smaller pulley and 404wftlbs and 341whp. So many factors go into the changes in numbers but I have to conclude that the supercharger just takes way more parasitic load and flow is really restricted now. Hoping porting and cams are the next step.
    tacotuesday81[QUOTED] likes this.
  3. Jul 22, 2019 at 12:04 PM
    #723
    tacotuesday81
    Darcy
    Other than the belt slip id say cams and porting will help for sure. Just cant breathe any heavier.
  4. Jul 22, 2019 at 12:07 PM
    #724
    Athlaos
    Leigh
    Edmonton
    Ya. I've been a bit disappointed in the numbers, but the low end torque is pretty fun.
  5. Jul 22, 2019 at 1:03 PM
    #725
    tacotuesday81
    Darcy
    Who you got doing dyno runs and what do they charge?
  6. Jul 22, 2019 at 1:18 PM
    #726
    Athlaos
    Leigh
    Edmonton
    Silver Maple Numerics just south of Spruce Grove. Great shop, charges me $100 (although he says that's a bit lower than usual because I'm a good customer). He's okay with more than just the 3 base runs if you want/need to as well.
  7. Jul 22, 2019 at 4:45 PM
    #727
    ThomasMore66
    Dallas/Fort Worth & Durango
    Is Kiel grinding yet? I want to be antisocial.
  8. Jul 22, 2019 at 5:13 PM
    #728
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Dont be antisocial. We would miss what you bring to the group. Just be eccentric southern rebel style.
    Torspd and Athlaos like this.
  9. Jul 22, 2019 at 5:19 PM
    #729
    ThomasMore66
    Hmm, I can’t post that...
  10. Jul 22, 2019 at 7:48 PM
    #730
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh: :quickdraw:
  11. Jul 22, 2019 at 7:48 PM
    #731
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So. I got a girlfriend that has a car. So now I have a second car. Much more confident on a cam swap now knowing i have something other than bus if things go south on install.
  12. Jul 22, 2019 at 8:23 PM
    #732
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im excited for install day. Its gunna be blast putting these in. Im chomping at the bit here
  13. Jul 22, 2019 at 8:33 PM
    #733
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Brave soldier. I'm pretty intimidated by this idea.
    WorldWar546 likes this.
  14. Jul 23, 2019 at 5:26 AM
    #734
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just remember, if all else fails, send it.
    ThomasMore66 likes this.
  15. Jul 23, 2019 at 5:27 AM
    #735
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    But seriously. If you can't get timing lined up just right without removing the timing cover, remove it. Better safe than sorry.
  16. Jul 23, 2019 at 1:08 PM
    #736
    Athlaos
    Leigh
    Edmonton
    Do you guys know of a place to get OEM timing chain kits? The dealership quoted me over $1100 for all the parts... If they're the only source of OEM then that's where I'd go, but I'm wondering if there's a situation similar to the water pumps where Aisin was selling their excess Toyota water pumps on Amazon for less than half the dealer's price, and grinding off the "toyota" mark.
    Not that I NEED to put a new timing chain in, but since I'm taking everything apart to do these cams, I might just say 'why the heck not'....
  17. Jul 23, 2019 at 2:06 PM
    #737
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Jul 23, 2019 at 3:50 PM
    #738
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I’m still here creeping... busy spending money on the tundra forums...
  19. Jul 23, 2019 at 3:51 PM
    #739
    Athlaos
    Leigh
    Edmonton
  20. Jul 23, 2019 at 3:53 PM
    #740
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am unable to access too
