CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jul 23, 2019 at 4:03 PM
    #741
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    @eljedi68 Check the first page for more information
    eljedi68 likes this.
  2. Jul 23, 2019 at 5:04 PM
    #742
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    https://www.toyotaofdallas.com/parts/shop.htm
    They used to be the other website that I linked above. They used to also have some of the best prices for online Toyota parts. Definitely double check.
  3. Jul 23, 2019 at 6:13 PM
    #743
    ThomasMore66
    Dallas/Fort Worth & Durango
    Are they ready yet?
  4. Jul 23, 2019 at 6:32 PM
    #744
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    What do you guys think about the install and tune of these? How difficult is this really gonna be? Us Cali guys will need to swap these out for every smog check. Even considering that, I’m debating on pulling the trigger. Thoughts?
  5. Jul 23, 2019 at 6:45 PM
    #745
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Sounds like a weekend of work before and after a smog test. If I had the shop to do it I probably would!
  6. Jul 23, 2019 at 6:47 PM
    #746
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    It’s not a technically difficult job, although time consuming as @White lightning boosted said. I live in Alberta which is the Texas of Canada, so I don’t have to worry about these things, but I’d probably just invest my money in a way to cheat the smog test.
  7. Jul 23, 2019 at 7:00 PM
    #747
    ThomasMore66
    Has anyone found the original cam specs?
  8. Jul 23, 2019 at 7:06 PM
    #748
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Post 33 has everything I know
  9. Jul 23, 2019 at 7:12 PM
    #749
    ThomasMore66
    Just wondering how much more lift we’re getting.
  10. Jul 23, 2019 at 7:27 PM
    #750
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I seriously doubt that these will need to be swapped out to smog. If your cats are healthy, you should be fine at the sniffer.
    Now, if you order some wild grind with tons of overlap that dumps a bunch of unburnt fuel down the exhaust, that’s another story.
    Custom tuning is now available for these trucks via hptuners. So, finish your hard-part mods and get it on a dyno.
  11. Jul 23, 2019 at 7:31 PM
    #751
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    They don't do the sniff test in California anymore, it's all visual and OBD2 reading. But if they can "hear" the cam, you may be in trouble. Other wise I doubt they are going to open up the motor to see you installed different cams.
  12. Jul 23, 2019 at 7:32 PM
    #752
    BillDaCat8
    Jake
    PHX
    @Torspd could potentially help here. He’s got cams already. He could compare them to some stockers and report the differences. We’d then just compare his cam specs to the ones we’re ordering and see.
    Last I saw though, he’d installed them and was buttoning it all back up.
  13. Jul 23, 2019 at 7:34 PM
    #753
    BillDaCat8
    Jake
    PHX
    Those mouth breathers aren’t going to fail the vehicle because it sounds funny. If the screen checks out and the visual is good, you’re good.
  14. Jul 23, 2019 at 8:01 PM
    #754
    BillDaCat8
    Jake
    PHX
    We’ve sure got a lot of Texans (and Canadian Texans :canada:) on tacoworld. Wild West!
    Just an observation. Carry on. :cheers:
  15. Jul 23, 2019 at 8:04 PM
    #755
    Jesse
    Poulsbo
    15' DCSB OR S/C
    For factory cam specs could we find #s from a hilux easier? Maybe they're the same?
  16. Jul 23, 2019 at 8:28 PM
    #756
    ThomasMore66
    #antisocial
  17. Jul 23, 2019 at 8:53 PM
    #757
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You only have until the 31, just remember. As long as the VVT-I is working, what these were spec'd for, then no codes to be found. Even the factory ECU won't care. It just won't be optimized.
    This^^^
    A quietish but more free flowing muffler than stock. Get more flow and keep the noise Nazi's at bay, perhaps?
    I still have access to them. Not completely buttoned up. Awaiting just like everyone else. Just taking care of other punch-list items in the mean time. I may be able to get the OEM dimensions, but that won't exactly translate to lift and duration. Without proper formulating. ;)
    As long as it is the same single VVT-I 1GR, and they have specs posted somewhere, then yes. Educated guess says that they have the same engines.
  18. Jul 27, 2019 at 8:53 AM
    #758
    ThomasMore66
    Anybody talked to Kiel? I feel like a kid waiting for Christmas.
  19. Jul 27, 2019 at 8:55 AM
    #759
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No. I feel the same. Eager for that fuel rail too. Should be a week or two for that as well.
  20. Jul 27, 2019 at 8:59 AM
    #760
    ThomasMore66
    Cams and I’m done. I promise...
    WorldWar546 and loginfailed like this.
