CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Aug 8, 2019 at 9:03 AM
    #841
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Should be one more week and then we hear an update hopefully!
    Roostfactor, Athlaos and GT7 like this.
  2. Aug 8, 2019 at 9:04 AM
    #842
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I bet I could adapt my car's turbochargers and exhaust
    BassAckwards likes this.
  3. Aug 8, 2019 at 9:19 AM
    #843
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have welder, can make.
  4. Aug 8, 2019 at 10:26 AM
    #844
    Athlaos
    Leigh
    Edmonton
    My cell phone got cut off. God damn Tacomaworld with all it's temping group buys. In hindsight, I should have opted to not pay my gas bill, since it's the warm season. Although, cold showers are a bit annoying...
  5. Aug 8, 2019 at 2:04 PM
    #845
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I see you noticed there are two little snails :D
  6. Aug 8, 2019 at 2:05 PM
    #846
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    All blanks are on the trays ready to load for us. Check your emails if you ordered some. Kiel just sent one.
    Roostfactor and Torspd like this.
  7. Aug 8, 2019 at 2:07 PM
    #847
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I saw the email. very excite
  8. Aug 8, 2019 at 2:29 PM
    #848
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Upload a pic for us jealous guys!
  9. Aug 8, 2019 at 2:29 PM
    #849
    Roostfactor
    TX panhandle
    What grinds are the sc peeps going with?
  10. Aug 8, 2019 at 2:33 PM
    #850
    GT7
    Grant
    Phoenix
    2013 DCLB
  11. Aug 8, 2019 at 3:43 PM
    #851
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  12. Aug 8, 2019 at 3:52 PM
    #852
    ThomasMore66
    Dallas/Fort Worth & Durango
    It's happening!
    Roostfactor, loginfailed and Torspd like this.
  13. Aug 8, 2019 at 4:10 PM
    #853
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I see mine!!!!! :D
    Roostfactor and loginfailed like this.
  14. Aug 8, 2019 at 4:14 PM
    #854
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Nice now I’m getting envy of not ordering but getting a bit ahead of myself.
  15. Aug 8, 2019 at 4:14 PM
    #855
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    First page, unless a buyer requested something with additional spice.
    Roostfactor[QUOTED] likes this.
  16. Aug 8, 2019 at 4:17 PM
    #856
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should be 44 there eh? Unless there was an additional buyer or so?
    Edit*** Just read the email. Has some additional cams in there.
  17. Aug 8, 2019 at 4:22 PM
    #857
    GT7
    Grant
    Phoenix
    2013 DCLB
    Point them out to me
    loginfailed likes this.
  18. Aug 8, 2019 at 4:36 PM
    #858
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They're right there, with the slightly different lobes. Look closer
    Roostfactor likes this.
  19. Aug 8, 2019 at 5:36 PM
    #859
    ThomasMore66
    I better get a sticker.
  20. Aug 8, 2019 at 5:49 PM
    #860
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have to buy two sets.
