CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Aug 28, 2019 at 11:38 AM
    #961
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    damn jealous. i have too much still to install. almost pulled the trigger bu keil and i agreed to wait until later
    BassAckwards, Athlaos and Roostfactor like this.
  2. Aug 28, 2019 at 11:41 AM
    #962
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    For the peeps who got cans and have a y-pipe on order:
    Are your cam specs the same as post 1?
    I will have to run some calculations to see how much different the y-pipe dimensions need to be to match the new cam profile.
    If there is a notable difference I will try to adjust the dimensions of the y-pipe to "tune" the y-pipe to the new engine/cam specs for optimal performance.
    I guess we also should get at least one truck running well on the new cams to see the power characteristics, then we can tune the y-pipe accordingly.
  3. Aug 28, 2019 at 11:42 AM
    #963
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I will have to send you a picture of my spec sheet tonight. It was slightly different than the sheet provided on Page 1.
  4. Aug 28, 2019 at 11:45 AM
    #964
    Roostfactor
    TX panhandle
    I'm seriously jealous too! But I have to sit this one out for now and let others be guiney pigs for this one.
    If they work well maybe we can get another gb going down the road?
    If you are down that's already 2. Then there is @DocME @5thGearPinned and others who may be down for the next run.
    How many does Kiel need for gb #2?
  5. Aug 28, 2019 at 11:48 AM
    #965
    Roostfactor
    TX panhandle
    Good deal! We may need to whip up something special for you.
  6. Aug 28, 2019 at 11:48 AM
    #966
    nudavinci64
    Robert
    p
    probably at least 10. i def need to get everything installed and workout any kinks and have you built me a CA friendly Y pipe =p
    Roostfactor[QUOTED] and Athlaos like this.
  7. Aug 28, 2019 at 12:01 PM
    #967
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Put me down for a maybe, but I’d prefer to hold off until next summer.
  8. Aug 28, 2019 at 3:43 PM
    #968
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Five.
  9. Aug 29, 2019 at 11:44 AM
    #969
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Yeah I want in on cam action when ever for gb2
    Roostfactor and loginfailed like this.
  10. Aug 29, 2019 at 11:57 AM
    #970
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    As long as another group buy doesn't happen for a month or two I will most likely be in
  11. Aug 29, 2019 at 12:30 PM
    #971
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I’m not in a hurry either
    Athlaos likes this.
  12. Aug 29, 2019 at 1:02 PM
    #972
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    im in for gb2 want to hear what they sound like tho
  13. Aug 29, 2019 at 2:02 PM
    #973
    Athlaos
    Leigh
    Edmonton
    I have faith that they'll sound amazing.
    Roostfactor likes this.
  14. Aug 29, 2019 at 3:46 PM
    #974
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Doesn't @Torspd have a sound clip on youtube of his engine with the stroker and cams? shouldn't sound much different than that.
    loginfailed likes this.
  15. Aug 29, 2019 at 3:56 PM
    #975
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Here's one I filmed a while back. :thumbsup:
    mav, Roostfactor, skyking3 and 7 others like this.
  16. Aug 29, 2019 at 5:55 PM
    #976
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That sounds so gnarly without the down-pipe attached!
    Others have heard the engine idle in its most current completed form. Yet no clips unfortunately.
  17. Aug 29, 2019 at 10:25 PM
    #977
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Someone say GB 2? :spy:
  18. Aug 30, 2019 at 5:21 AM
    #978
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I forgot to mention there was no down pipe on at the time. We definitely need to make some more videos!
  19. Aug 30, 2019 at 6:14 AM
    #979
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Coffee and Cars next weekend???? I have to do a few more things to the Bimmer this weekend. Including a rear wheel bearing. Then I can focus on the truck. Hopefully I will be able to get started on it this weekend.
    Athlaos and loginfailed[QUOTED] like this.
  20. Aug 30, 2019 at 6:47 AM
    #980
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The 7th is my turn to hold down the fort at the shop, unfortunately. :pout:
    Athlaos likes this.
