CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 28, 2019 at 8:00 AM
    #81
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Same. Im curious if you can do it without removing the timing cover.
  2. Jun 28, 2019 at 8:05 AM
    #82
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I would need to do this to a newer engine than my current one to justify it.
  3. Jun 28, 2019 at 12:56 PM
    #83
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I really don’t think that’s a worry at all. These cams retain the vvt. That’s your wide powerband and fat torque down low. Tor’s cams eliminated the vvt. That’s why he lost some umph down low.
    Think of these as a “second gen” version.
  4. Jun 28, 2019 at 12:59 PM
    #84
    BillDaCat8
    Jake
    PHX
    Then you can sell the current ones along with that piggyback you’re selling.
  5. Jun 28, 2019 at 1:17 PM
    #85
    ThomasMore66
    Dallas/Fort Worth & Durango
    For sure add me to this list. We should add lighter valves so we can rev higher. I see rods and pistons coming...
  6. Jun 28, 2019 at 1:22 PM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    SuperTech and Ferrea. OEM dimension valves from SuperTech are considered a custom order. Not from Ferrea. Ferrea are more expensive. They both offer a variety of valve types by material.
  7. Jun 28, 2019 at 3:03 PM
    #87
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nearly had the valve covers off to set timing, and the stupid rain clouds came in to check out the action....:rain:
    Looky what's in the background. ;)
  8. Jun 28, 2019 at 3:05 PM
    #88
    GT7
    Grant
    Phoenix
    2013 DCLB
    Fuel lab fpr with built in gauge?
  9. Jun 28, 2019 at 3:09 PM
    #89
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thread in. Has a plugged port in for whatever. 1/8" NPT.
    GT7[QUOTED] likes this.
  10. Jun 28, 2019 at 4:06 PM
    #90
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You getting any hail over there? :crapstorm:
  11. Jun 28, 2019 at 4:12 PM
    #91
    BillDaCat8
    Jake
    PHX
    We're already plenty amok. But I like where your head is at.
  12. Jun 28, 2019 at 4:13 PM
    #92
    BillDaCat8
    Jake
    PHX
    I see a TIG finger. Somebody's got a new toy.
    Roostfactor likes this.
  13. Jun 28, 2019 at 4:15 PM
    #93
    GT7
    Grant
    Phoenix
    2013 DCLB
    Thats 5 people :spending:
  14. Jun 28, 2019 at 4:37 PM
    #94
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank God no.
    loginfailed[QUOTED] likes this.
  15. Jun 28, 2019 at 4:37 PM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Old toy. ;)
  16. Jun 28, 2019 at 4:42 PM
    #96
    BillDaCat8
    Jake
    PHX
    I suppose that is G. Ok Thomas, yer in.
    Torspd, BassAckwards and GT7[QUOTED] like this.
  17. Jun 28, 2019 at 5:08 PM
    #97
    BillDaCat8
    Jake
    PHX
    Whaddya say Tor? A new set of turbo VVT cams? Hmmm? :boink:
  18. Jun 28, 2019 at 5:19 PM
    #98
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lol. Don't need a new set. Only the intake.
  19. Jun 28, 2019 at 9:48 PM
    #99
    ThomasMore66
    So what are the specs on the cams? I want a rumpity idle and more hp.
  20. Jun 28, 2019 at 9:52 PM
    #100
    BillDaCat8
    Jake
    PHX
    Specs for the SC grind are in the first post. Everyone is still hunting for the stock specs for comparison tho. It seems that Toyota hasn’t exactly made this information public.
