CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Aug 30, 2019 at 6:56 AM
    #981
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'll bring it by there. ;)
  2. Aug 30, 2019 at 7:28 AM
    #982
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I think I'll have to wait a while for install. finances are drained currently and both doing it myself and/or having a shop do it correctly makes me nervous after reading @Torspd 's write up correct start up procedure.
    Athlaos likes this.
  3. Aug 30, 2019 at 8:28 AM
    #983
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    To piggyback off this, @Torspd Does this mean you have to run high zinc oil all the time or just for the break in period?
  4. Aug 30, 2019 at 8:49 AM
    #984
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I always do.
    If I cannot get Redline Oil, I'll get Castrol or Mobile One. Either of theirs with the European blend, or high anti-wear mentioned. Typically a 5w-40 full synthetic. Then I add in a half bottle of Redline Oil Engine Break-in Oil(bottle of anti-wear additive). Always.
    Redline has a very high ZDDP count.
    Amsoil Dominator series does too, I just don't know how much. Those two don't need the added bottle of anti-wear additive.
  5. Aug 30, 2019 at 8:56 AM
    #985
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Start-up procedure is easy enough. Lube up cams like crazy. Add a little extra oil to buckets around the bucket shims. Pull fuel pump relay. Crank for a few seconds to build oil pressure. Jump fuel pump contacts while key is in "On" position, to prime fuel rail. Reinsert relay. Start engine and maintain 2000-2500 RPMs until engine is at operating temperature. Done.
  6. Aug 30, 2019 at 6:08 PM
    #986
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    1 - Fantasize about Tacoma with cams smashing around town
    2 - Decide I don’t need and can’t afford cams
    3 - Realize I really do need cams
    4 - Tell myself it’s ok to buy bc it will complete my truck and I’ll be done
    5 - Get excited everyday about cams coming
    6 - Get delivery and smile
    7 - Open box and think “when do I have time to put these in and how the fuck do I do it”
    8 - Put on shelf in garage with all other parts
    9 - Drive stock Tacoma around town
  7. Aug 30, 2019 at 6:24 PM
    #987
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    This post compliments my PBR well... I love it.
    :rofl:
    Torspd and BassAckwards like this.
  8. Aug 30, 2019 at 7:17 PM
    #988
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm with you until step 9. finally someone that thinks like me.
  9. Sep 2, 2019 at 9:46 AM
    #989
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Anyone started on their cams yet?
  10. Sep 2, 2019 at 10:30 AM
    #990
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yes!
    oh, misread. thought you said stared at.
    loginfailed likes this.
  11. Sep 2, 2019 at 11:21 AM
    #991
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Technically I did last night. I upackaged the Kelford box from the shipping box. 1st step down. Lol.
    Actually, I just finished working on my Bimmer. Time to get started.
  12. Sep 2, 2019 at 1:13 PM
    #992
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im excited to see the install process and reviews.
    TodayWasTHeDaY likes this.
  13. Sep 2, 2019 at 2:35 PM
    #993
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Rush to get them, then they sit for a few weeks until install. Perfectly describes my efforts.
    Roostfactor and Torspd[QUOTED] like this.
  14. Sep 2, 2019 at 2:47 PM
    #994
    Jesse
    Poulsbo
    15' DCSB OR S/C
    as long as there's a discount to be had it makes sense to me. i feel like a chick that sees a shoe sale.
  15. Sep 3, 2019 at 1:27 PM
    #995
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I almost moved the Kelford box to the garage from the living room. There was good intent.
  16. Sep 3, 2019 at 5:12 PM
    #996
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No cam work, but did organize the garage for working on the cams, as well as just finished welding on an exhaust hanger support for friend's 2TR. That has a custom Torspd modified exhaust. Still need to get a turbo on that engine..... One day soon. :devil:
  17. Sep 3, 2019 at 5:30 PM
    #997
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Found an engine worth buying to build up. Commercial freight delivery only. Now my welding shop isn't big enough to be considered commercial so so now I need to call in favors. Once the engine is purchased, BC stroker wont be a far purchase behind that. Now who's setting up the group by on stroker kits anyways lol
    Hawk373, Roostfactor, Torspd and 2 others like this.
  18. Sep 3, 2019 at 5:35 PM
    #998
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im down if its a group buy
  19. Sep 3, 2019 at 5:38 PM
    #999
    Jesse
    Poulsbo
    15' DCSB OR S/C
    usually the nearest freight hub will let you pick things up. thats how my axles worked out.
  20. Sep 3, 2019 at 5:41 PM
    #1000
    mightytacoman
    Kel
    4.5L 1grfe
    My man. 2 down probably a few more to go.
    UPS near me says they do freight delivery. I'll have to talk to them. Dont know if they would do it for free like some of my steel suppliers might.
