CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Oct 5, 2019 at 8:57 AM
    #1061
    ThomasMore66
    Dallas/Fort Worth & Durango
    I never did ask Kyle what the valve springs were good for.
  2. Oct 5, 2019 at 9:28 AM
    #1062
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said. ^^^ The valve train will amply handle the higher limit. The OEM rods will protest until they rage quite with a big scene.
  3. Oct 5, 2019 at 6:23 PM
    #1063
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Ok, what about when you have a built engine with forged pistons, rods, upgraded valves and springs etc? What RPM limit can you go to? I was wondering this just this morning driving to work.
  4. Oct 5, 2019 at 6:25 PM
    #1064
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oil pump becomes the unknown.
  5. Oct 5, 2019 at 6:27 PM
    #1065
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    6000 is good for me. Oil ‘er up just fine.
  6. Oct 5, 2019 at 6:29 PM
    #1066
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Wasn't there a tuner before the ucon that took it up to 6200 rpm? The x1 I think.
  7. Oct 5, 2019 at 6:50 PM
    #1067
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD dyno'd their stroker engine XRunner up to 7000 RPM's I believe. Then dialed it back to 6 or 6200 for normal driving. That was with the UCON running the engine.
  8. Oct 6, 2019 at 9:41 AM
    #1068
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Had an idea.
    Maybe the buckets that get swapped out, we post up the thicknesses. Perhaps someone else can use them for their install. Assuming that they’re in good shape of course.
  9. Oct 6, 2019 at 1:26 PM
    #1069
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Good idea, I’d be happy to ship my unused buckets once I remove them. Stupid Canada, I’m waiting 7-10 business days for the new lifters because they’re coming from the US.
  10. Oct 10, 2019 at 1:19 PM
    #1070
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Roostfactor likes this.
  11. Oct 10, 2019 at 1:21 PM
    #1071
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Part 2. Had to figure out some tune differences was quite time consuming. Otherwise is would have just been one video.
    https://youtu.be/NYSLpBbVwc8
    mav, Roostfactor and Murphinator like this.
  12. Oct 10, 2019 at 6:31 PM
    #1072
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    we need idling video!
    BillDaCat8[OP] likes this.
  13. Oct 10, 2019 at 9:28 PM
    #1073
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In my build thread!!!
    Athlaos and Murphinator[QUOTED] like this.
  14. Oct 11, 2019 at 9:41 AM
    #1074
    Athlaos
    Leigh
    Edmonton
    @Torspd I'm in a jam over getting my new lifters in. Here in communist Canada apparently they take an extraordinarily long time to arrive... Do you have any of the old ones that you could ship to me provided they're the right size?
  15. Oct 11, 2019 at 10:43 AM
    #1075
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sorry to hear that man! All of mine that are available are all in the low 40's or 30's. I have a feeling that you need thicker than those correct?
  16. Oct 11, 2019 at 12:25 PM
    #1076
    Athlaos
    Leigh
    Edmonton
    I need three 46, two 32 and one 30
  17. Oct 11, 2019 at 12:44 PM
    #1077
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I may have those. Going to be at least until tomorrow for me to look.
  18. Oct 11, 2019 at 12:47 PM
    #1078
    Athlaos
    Leigh
    Edmonton
    Thanks!
  19. Oct 11, 2019 at 12:51 PM
    #1079
    mightytacoman
    Kel
    4.5L 1grfe
    I gotta pull the heads anyways. Should make changing out the springs much easier for me.
    Athlaos likes this.
  20. Oct 11, 2019 at 1:02 PM
    #1080
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    100%
    Athlaos likes this.
