CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 28, 2019 at 9:55 PM
    #101
    ThomasMore66
    Dallas/Fort Worth & Durango
    Ugh. mm. I’ll have to do some math.
  2. Jun 28, 2019 at 10:20 PM
    #102
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Stay tuned
  3. Jun 29, 2019 at 4:29 AM
    #103
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    To buy a slightly used engine and go this route or not. Wouldn't mind getting rid of my 200k post flood engine. Something about that 8ft of water for a few hours does make it burn more oil than it did.
    Roostfactor likes this.
  4. Jun 29, 2019 at 5:38 AM
    #104
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Do it!
  5. Jun 29, 2019 at 5:46 AM
    #105
    GT7
    Grant
    Phoenix
    2013 DCLB
    Same.
  6. Jun 29, 2019 at 7:05 AM
    #106
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'll reread this all but so cam gears would be unnecessary with new cams? What's a guesstimate on price?
  7. Jun 29, 2019 at 7:07 AM
    #107
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Basically I'm in for sure, the question is when. Round two for sure:thumbsup:
  8. Jun 29, 2019 at 7:19 AM
    #108
    GT7
    Grant
    Phoenix
    2013 DCLB
    Unknown. Maybe 150 off?
  9. Jun 29, 2019 at 7:22 AM
    #109
    BillDaCat8
    Jake
    PHX
    I’m hoping for better than that.
    We’ll see on Monday I hope.
  10. Jun 29, 2019 at 7:30 AM
    #110
    GT7
    Grant
    Phoenix
    2013 DCLB
    Maybe free shipping & $100 off. That would be good
  11. Jun 29, 2019 at 7:42 AM
    #111
    ThomasMore66
  12. Jun 29, 2019 at 8:03 AM
    #112
    GT7
    Grant
    Phoenix
    2013 DCLB
  13. Jun 29, 2019 at 8:08 AM
    #113
    ThomasMore66
    GT7[QUOTED] likes this.
  14. Jun 29, 2019 at 10:49 AM
    #114
    ThomasMore66
    Seriously, if the heads are coming off, seems like we should go the next step on valve-train. Maybe some porting/polishing?
  15. Jun 29, 2019 at 10:53 AM
    #115
    GT7
    Grant
    Phoenix
    2013 DCLB
    Well I dont plan on taking my heads off for this. Unless I missed something
  16. Jun 29, 2019 at 10:58 AM
    #116
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The heads wouldn’t need to come off. But if you’re going to port the heads, the time to do it would be during the tear down for cam installation. You’re halfway there.
    Heads and cams combined will get the most from each mod.
    At that point you might as well drop in a set of pistons and rods and rev it out.
    DiamondW likes this.
  17. Jun 29, 2019 at 11:00 AM
    #117
    ThomasMore66
    I’m curious how much lighter valves would cost. What’s our rpm limiter right now? I thought valve springs. Also, @Roostfactor has posted a chart of SC efficiency vs rpm. Maybe we can’t get much more even if the limiter gets raised.
  18. Jun 29, 2019 at 11:06 AM
    #118
    GT7
    Grant
    Phoenix
    2013 DCLB
    I have 0 interest in raising the limiter. But depending on what install entails, Ill get some valves
  19. Jun 29, 2019 at 11:09 AM
    #119
    JustDSM
    Justin
    Ogden, UT
    If you want to factor in the airflow of the blower (MP90), I wouldn’t bother with the rods, pistons, porting, etc.
    I think you guys with smaller pulleys are already beyond efficiency zone.
    To get your moneys worth from an investment in the above parts I’d want the airflow potential of my blower/turbo to be able to efficiently operate in the newly expanded RPM range.
    But that’s just my 2¢.
    Your limiter is 5600 RPM
  20. Jun 29, 2019 at 12:42 PM
    #120
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I got 20 years.
    I think @ThomasMore66 finally wins something as he might be the oldest! :D
