CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Nov 12, 2019 at 6:40 PM
    #1181
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Gears can be done any time. Cams should be done while you’re already in the motor.
  2. Nov 12, 2019 at 6:40 PM
    #1182
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Both can be added at a later date when your money isn't as tight. The cams are a more tedious install though
  3. Nov 12, 2019 at 6:55 PM
    #1183
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Get em
  4. Nov 12, 2019 at 7:29 PM
    #1184
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    your in the motor. cam the motor. lift, gears, etc can always happen in time. cams=30-40 hp. do it.
    Torspd and 5thGearPinned like this.
  5. Nov 13, 2019 at 6:06 AM
    #1185
    mightytacoman
    Kel
    4.5L 1grfe
    Speaking of being in the motor, I'm wondering about doing head work and what could be gained there. My builder says with forced induction setups a 1:1 for intake to exhaust valve sizing is preferred. For naturally aspirated exhaust is usually 80% of the intake in size. Our intake valves measure 36.5mm, exhaust 29.5mm. Finding 1mm over is easy. And I might have found 2mm over for exhaust valves but I need to do more research. Anyone want to throw a wild number out there as to how much would/might be gained by going 2mm over in the exhaust and or intake?
  6. Nov 13, 2019 at 7:39 AM
    #1186
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    what do the valve springs look like that the cams come with? come with retainers too?
  7. Nov 13, 2019 at 12:07 PM
    #1187
    mightytacoman
    Kel
    4.5L 1grfe
    Springs are slightly shorter, come with a fancy washer like piece to get the length correct. No they don't come with retainers
  8. Nov 19, 2019 at 6:12 PM
    #1188
    GT7
    Grant
    Phoenix
    2013 DCLB
    @athalos
    update?
  9. Nov 19, 2019 at 6:13 PM
    #1189
    GT7
    Grant
    Phoenix
    2013 DCLB
    I just got 1 mm over cuz why not. Itll be fine either way I figure
  10. Nov 19, 2019 at 6:14 PM
    #1190
    Jesse
    Poulsbo
    15' DCSB OR S/C
    update is he may do a US visit soon! told him to stop in the pnw 1st.
    Athlaos likes this.
  11. Nov 20, 2019 at 4:39 AM
    #1191
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What he said! Is that s/c belt on yet?!
    BillDaCat8[OP] and Athlaos like this.
  12. Nov 20, 2019 at 1:08 PM
    #1192
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Belt still not on. Haven't been motivated to install it - roads have been so icy that it doesn't matter. Procrastination maybe but I'm justifying it by saying I'm doing tuning for minus 10 to zero manifold vacuum conditions.
    TRON and GT7[QUOTED] like this.
  13. Nov 20, 2019 at 1:29 PM
    #1193
    Athlaos
    Leigh
    Edmonton
    Yes, I am planning a trip down there! Might end up being in two parts, though - one in the spring and one in the fall. Depends how my work schedule settles.
  14. Nov 20, 2019 at 3:56 PM
    #1194
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Makes sense. At least all is running well.
    Athlaos[QUOTED] likes this.
  15. Dec 8, 2019 at 3:59 PM
    #1195
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Ok. Still waiting for review on the cams?
    TRON likes this.
  16. Dec 13, 2019 at 12:02 PM
    #1196
    Athlaos
    Leigh
    Edmonton
    I did my first oil change. No metal flakes came out and there wasn't any metal filings on the drain plug magnet. I guess I did the install correctly.
  17. Dec 13, 2019 at 2:58 PM
    #1197
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's a damn relieving sign.
    Athlaos likes this.
  18. Jan 4, 2020 at 6:28 PM
    #1198
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    gonna pull the trigger on the cams. emailing Kiel tonight. unless anyone have regrets and wants to sell theirs? I'll cover shipping.
    Torspd, JustDSM and Athlaos like this.
  19. Jan 5, 2020 at 5:22 AM
    #1199
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Emailed him the other day. Won’t be back till Monday.
    henryp[QUOTED] likes this.
  20. Jan 5, 2020 at 8:41 AM
    #1200
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I haven’t seen much action in here lately.
