CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Feb 20, 2020 at 6:34 AM
    #1281
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Yeah. I can’t read. Same here.
  2. Feb 20, 2020 at 6:54 AM
    #1282
    henryp
    Henry
    Montana
    What’s not clear is whether they will box it or when they are coming to pick it up (if they even do). fed Ex is about an hour away for me and I’m not about to take time off work for this.
  3. Feb 20, 2020 at 2:29 PM
    #1283
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Ya dude I’m lost too. I told them to just get me a shipping label and fedex does pickups at my work. But they want to pick it up from home. That’s not gonna happen. This is turning into a pain
  4. Feb 24, 2020 at 7:45 PM
    #1284
    henryp
    Henry
    Montana
    Sent the cams back this AM. By the afternoon I had a message my replacement ones were on the way. Hoping they sent me some merch.
  5. Feb 28, 2020 at 3:58 PM
    #1285
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    @henryp got SnapBack hat and hoodie! Love hoodies. And new cams haha. What u get? Don’t wear snap backs. Who wants it?
    BassAckwards and mightytacoman like this.
  6. Feb 28, 2020 at 3:59 PM
    #1286
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I'd rock that hat
  7. Feb 28, 2020 at 4:07 PM
    #1287
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Front and back of hoodie. @mightytacoman im gonna give @henryp first dibs on the hat if he wants it if not it’s yours.
  8. Feb 28, 2020 at 4:11 PM
    #1288
    mightytacoman
    Kel
    4.5L 1grfe
    Ya sounds good man :cheers:
  9. Feb 28, 2020 at 5:44 PM
    #1289
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I’m pretty sure I already asked this but u are running cam gears with your cams? Still trying to figure out to do it or not.
  10. Feb 28, 2020 at 5:59 PM
    #1290
    mightytacoman
    Kel
    4.5L 1grfe
    I'm not but I keep thinking I want to try it. Maybe even 2° instead of 3°
  11. Feb 28, 2020 at 6:08 PM
    #1291
    henryp
    Henry
    Montana
  12. Sep 8, 2020 at 11:13 PM
    #1292
    NashMan
    NashMan Well-Known Member
    I am debating about getting a set since my valve seal's are leaking but the question is how good do these fit ie not haveing the option to swap shims around since there far cheaper than full bucket.
    and I figure there should be some good gains since our cam shafts stock are more forword being a n/a cam than a supercharged cam.
    this would give me motivation to do my valve seal's
    oh ya most importantly will the valves hit when rolling to check valve lash ?
  13. Sep 12, 2020 at 7:00 PM
    #1293
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Round 2?
    JacksonTacoma likes this.
  14. Sep 12, 2020 at 7:11 PM
    #1294
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    +1 for Round 2
    jojotoo likes this.
  15. Sep 12, 2020 at 8:00 PM
    #1295
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    +2
  16. Sep 13, 2020 at 5:26 AM
    #1296
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I only needed one new bucket full I messed a valve up. All overs were in spec.
    When checking valve last just set to top dead center on cylinder one and then spin another 90 degreees and no valves will
    Hit any pistons.
    Torspd likes this.
  17. Sep 21, 2020 at 8:51 AM
    #1297
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @Torspd do you think there are gains over the static intake gear cams that you have? Or what would you say the power band differences are?
    TodayWasTHeDaY likes this.
  18. Sep 21, 2020 at 8:54 AM
    #1298
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I took them out and reinstalled the OEM cam gears. Lost a lot of low end torque, without them.
  19. Sep 21, 2020 at 8:59 AM
    #1299
    Athlaos
    Leigh
    Edmonton
    Interesting. So you think the Kelfords from this thread result in more low end than OEM?
  20. Sep 21, 2020 at 9:25 AM
    #1300
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was a comparison of them without it versus with it. I can feel a difference with the OEM ones, but I don't know how much that translates to on a dyno.
