CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 29, 2019 at 12:47 PM
    #121
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Heads do not need to come off to install cams.
    loginfailed likes this.
  2. Jun 29, 2019 at 12:48 PM
    #122
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    What about valves? I feel like you dont need to remove the heads. Lets buy some valves
  3. Jun 29, 2019 at 12:49 PM
    #123
    BillDaCat8
    Jake
    PHX
    You would need to pull the heads to do valves though.
    I have no intention of pulling the heads unless there’s a problem at some point.
    JustDSM and GT7 like this.
  4. Jun 29, 2019 at 1:05 PM
    #124
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Agreed to an extent.
    Ultimately the blower is too small for bigger hp numbers BUT, less restriction via cams, porting, sc inlet, etc allows the same or increased flow with less boost/heat.
    Also meth lowers the temp back down which I think would change the efficiency island.
  5. Jun 29, 2019 at 1:13 PM
    #125
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The addition of methanol/alcohol doesn't change the efficiency of the compressor. You're just cooling the heated charge, gaining back some air density.
  6. Jun 29, 2019 at 1:56 PM
    #126
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Should be able to do cams with out taking front cover off. As long as u can get the bolt out of the cam gear for the intake cam it’s possible.
  7. Jun 29, 2019 at 3:28 PM
    #127
    ThomasMore66
    Dallas/Fort Worth & Durango
    Oh yeah. Add 4 more years.
    Roostfactor[QUOTED] likes this.
  8. Jun 29, 2019 at 7:46 PM
    #128
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    They do if you’re doing what I would be doing.
    JustDSM likes this.
  9. Jun 29, 2019 at 7:48 PM
    #129
    GT7
    Grant
    Phoenix
    2013 DCLB
    :goingcrazy: Elaborate
  10. Jun 29, 2019 at 7:48 PM
    #130
    JustDSM
    Justin
    Ogden, UT
    Scraping the carbon off the top of your pistons? :p
  11. Jun 29, 2019 at 7:49 PM
    #131
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Installing bigger ones.
  12. Jun 29, 2019 at 8:02 PM
    #132
    GT7
    Grant
    Phoenix
    2013 DCLB
    I dont know if I should install these or save them for my spare engine
    loginfailed[QUOTED] likes this.
  13. Jun 29, 2019 at 8:24 PM
    #133
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Install them now and then swap them over when your sleeved and stroked engine is ready.
  14. Jun 29, 2019 at 8:26 PM
    #134
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im thinking sleeves. Want stroker but for the money Im pretty iffy on it.
    Probably will install these on my motor now. Im too damn excited
  15. Jun 29, 2019 at 8:41 PM
    #135
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  16. Jun 29, 2019 at 9:45 PM
    #136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No body is getting any more on a raised rev limit, with boost, on stock internals, except a bunch of freshly installed port holes by Uncle Rodney. Lol.
  17. Jun 29, 2019 at 9:52 PM
    #137
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That was the infamous Balboa. Banned from a few forums. Never finished his build. X-1 could not handle the load that they were creating. I experienced and proved that loooong before they encountered that. Told them the issue. Scott had already stopped working with APR by that point. They were screwed. Or had to get a standalone. Balboa was the fund source for APR to have fun with that truck and build.
    That truck was sold and still is seen around San Antonio occasionally. Looks dilapidated.
    I have a short one of their videos either in my Photobucket account or YouTube. When they were doing testing of the rear mounted turbo + TRD s/c configuration. On the built engine in the link.
  18. Jun 29, 2019 at 9:55 PM
    #138
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So NOW sleeved engines are a cool thing?
  19. Jun 29, 2019 at 9:57 PM
    #139
    GT7
    Grant
    Phoenix
    2013 DCLB
    I see the test pull video.
    When were they not? Sounds damn cool to me
  20. Jun 29, 2019 at 9:59 PM
    #140
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
