CLOSED. Kelford Cams for 1GR GB.
Discussion in 'Performance and Tuning' started by BillDaCat8, Jun 27, 2019.
  1. Jun 29, 2019 at 10:02 PM
    #141
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
  2. Jun 29, 2019 at 10:03 PM
    #142
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    One on a stand and one in the truck. Good thing the CFS Radiators are in most of your trucks. They require a larger capacity radiator and 160° t-stat. Sleeves and built, means Tacoma drivers get the digital black shades :cool: when pulling on Hellcats. :laugh:
    mav and Roostfactor like this.
  3. Jun 29, 2019 at 10:04 PM
    #143
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
    GT7[QUOTED] likes this.
  4. Jun 29, 2019 at 10:07 PM
    #144
    GT7
    Grant
    Phoenix
    2013 DCLB
    Sleeves run that much hotter huh? I have that already but with sleeves more may be necessary for me.
  5. Jun 29, 2019 at 10:07 PM
    #145
    ThomasMore66
    Dallas/Fort Worth & Durango
  6. Jun 29, 2019 at 10:08 PM
    #146
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just remember. A little thanks needs to go to Gadget for paying for the first set of Darton sleeves to be made. Luckily, he knew a guy who had a bare blown engine to donate to the cause. Ahem ahem. Lol.
    We're getting waaaay off topic though. Keep in mind. Upgrading the valve springs needs to be seriously considered. Seriously. We did a test.
  7. Jun 29, 2019 at 10:09 PM
    #147
    ThomasMore66
    I’ve read a bunch of threads.
  8. Jun 29, 2019 at 10:10 PM
    #148
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Dang it. That's the wrong video. That was a stock engine. Not the one in the thread. Not Balboa's.
  9. Jun 29, 2019 at 10:10 PM
    #149
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yeah the kelford guy said they were necessary. Ill be getting them
    Torspd[QUOTED] likes this.
  10. Jun 29, 2019 at 10:10 PM
    #150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Jun 29, 2019 at 10:11 PM
    #151
    ThomasMore66
    And some rods and pistons...
  12. Jun 29, 2019 at 10:12 PM
    #152
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ductile iron. Small sacrifice for a repairable block, and super strong cylinders that have an integrated closed deck.
  13. Jun 29, 2019 at 10:12 PM
    #153
    GT7
    Grant
    Phoenix
    2013 DCLB
    I gotta save money for that. If anything Ill take the spare block and get the sleeves installed to start, then keep saving monies
  14. Jun 29, 2019 at 10:13 PM
    #154
    GT7
    Grant
    Phoenix
    2013 DCLB
    Do you recall how much you can bore with out intruding on the space you want left for it to be repairable?
  15. Jun 29, 2019 at 10:14 PM
    #155
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't forget the correct video that I just posted, since posts are coming in quickly.
    GT7 likes this.
  16. Jun 29, 2019 at 10:19 PM
    #156
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I went to nearly .100" over. It was under that, but not much. .095-.098." Don't do that. Very hard to get head gaskets made. You don't want to get custom copper gaskets either.
    Anywhere from stock @ 3.701" to .050" over and your ok. I wouldn't go any past .050" if I did it again. To further validate that, Darton themselves can tell you as well, how much material can be removed.
  17. Jun 29, 2019 at 10:21 PM
    #157
    GT7
    Grant
    Phoenix
    2013 DCLB
    Maybe Ill just stay 4.0 and spend money else where.
    Cmon lurkers we got a solid 5 for cams. Lets get 10
  18. Jun 29, 2019 at 10:21 PM
    #158
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  19. Jun 29, 2019 at 10:21 PM
    #159
    GT7
    Grant
    Phoenix
    2013 DCLB
    Someone unknown now.
  20. Jun 29, 2019 at 10:24 PM
    #160
    ThomasMore66
    Even NA folks should like this.
